Another Manta Project - This Time In New Zealand
Page 3 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 51 to 75 of 131
Thread: Another Manta Project - This Time In New Zealand
  1. #51
    Jul 2011
    Auckland, New Zealand
    Opel Manta+Astra 2.2 16V
    Re: Another Manta Project - This Time In New Zealand
    Quinton Hazell inner and outer track rods arrived today, will get these fitted tonight and will be the front sub frame and suspension finished.
    these were a bit tricky to track down in QH but worth the effort I think.
    Jul 2011
    all finished and on the trolley, set aside for install at a later stage, pretty happy with the end result.
    Lessons learned?
    I would not go with powder coating again.
    • Media blasted
    • Lower wish bones reinforced
    • 2 pack rust killer primer
    • Powder coated satin black
    • Full poly bush kit
    • Springs reset and powder coated
    • Poly seats for springs
    • Poly short bump stops
    • New ball joints
    • New track rods & ends
    • All new high tensile nuts bolts & washers
    • Audi 80 front vented disc conversion
    • Opel Vectra / Calibra 16V calipers fitted with new seals and pads
    • New front wheel bearings
    And many hours of work in my little shed
  4. #53
    Nov 2011
    Barcelona Spain
    Ascona C GT Turbo
    Amazing proyect, congratulations.
  5. #54
    Jul 2011
    interesting reading.
  6. #55
    MIGClub Member RodOGW's Avatar
    Jul 2009
    Norfolk
    Calibra 2.0i 94
    Quote Originally Posted by opelmantagsi View Post
    Lessons learned?
    The work is beyond superb - no single factor - just an overall impression that everything is done right and to highest quality...
    Anyway - why don't you like powder coating - I know people who swear by it and some who actually work in the industry - however I am not a big fan myself and cannot quite put my finger exacly on why?
  7. #56
    Jul 2011
    thanks for the posting and positive feedback.
    yes I am pretty happy with the end result but would not do the powder coating thing on an assembly like this again, mainly due to its tenancy to chip during reassembly. there were a couple of bits that took a small knock (metal on metal) while putting the bushes in and I was very annoyed at myself initially for being careless, touching up is difficult and it stands out as a chip, whereas paint could have been rubbed down and gone over properly.
    I have powder coated the seat rails, rail mounts and foot pedals they have come up great and doubt they will see any damage but for the sub frame / suspension I would not do again, could be the powder coat process was not quite right but that's just my experience and I would not go there again, but it does look nice in satin black I must say and anyone that's seen it in real life has gone ....oooo....aaaa....
  8. #57
    Jul 2009
    Norfolk
    Calibra 2.0i 94
    I agree with you totally regarding chipping aspect - we use large powder coated sheet at work and they seem to have very little resitance to scratcing as well. The trouble is that enamel paints like Hammerite are also quite prone to chipping.
    I remember a few years ago that some guys in the restoration business started using polyurethane household paints on suspension parts etc. as it was more flexible so less likely to chip and just as resistant to wear and tear.
  9. #58
    Jul 2011
    here is a aluminium step off a brand new truck imported into NZ, these get removed by the NZ supplier on units being modified to twin steer and come handed.
    plan is to cut this up and fold to make a combined floor tray / navigators foot rest for passenger side and flat floor tray with clutch foot rest fro drivers side
    bolt through the floor with nice stainless steel allen key bolts with rubber grommets between floor and tray to keep the plate clear of the steel floor pan and provide a gap for pipes and wires to run between.
    this is a task for a bit further down the track, will be interesting to see how it goes
  10. #59
    Jul 2011
    got my COSCAST head back today, here are some pics showing the bronze valve guides.
    work done
    head acid dipped
    crack tested
    cast iron valve guides removed
    warm fit 13.05mm over sized bronze guides (QED supplied) & ream to suit new valves
    cut valve seats to suit new valves and vacuum test.
    heater hose connection replaced with new GM part
    core plugs replaced with new GM parts
    head skimmed
    chase spark plug threads to clear
    remove 1 x broken stud
    head acid dipped & washed following machining
    new exhaust flange studs (to fit)
  11. #60
    Jul 2011
    new hydraulic lifters / cam followers to fit
    new studs to fit
  12. #61
    Jul 2011
    funny you mention it I am talking with a specialist coating supplier at the moment as I want to use a two pack urethane / epoxy paint system to do the entire inner floor pan, base coat will give me a dimple effect and then a top coat with a urethane glaze tinted polar white to match he final car colour, watch this space...
  13. #62
    Apr 2005
    Derby
    Way too Fast :-/
    Fantastic thread and project!
    Still aghast at how you managed to find such a rust free manta to start with
  14. #63
    Jul 2011
    today's progress putting the head back together. the head is on stands to prevent the open valves getting damaged.
  15. #64
    rc
    rc is online now
    MIGClub Member rc's Avatar
    Jan 2007
    Felixstowe, suffolk!
    359.9bhp astra
    great progress
  16. #65
    Jul 2011
    SBD cam cover breather modification
    SBD Motorsport - 16v Vauxhall tuning
    Removal of the small cam cover breather hose connection using a hinge pin removal tool, the hole will be blanked off with a nut and bolt.
    Cam covers now off to be put through a commercial parts washer prior to being paint stripped ready for high temperature coating by HPC
    > Superior Appearance Coatings
  17. #66
    Jul 2011
    custom made Delrin engine mount bobbins and Delrin gear shift knob
  18. #67
    South East Regional Co-ordinator
    Apr 2011
    Sheerness, Kent.
    2003 Arden Zafira GSi
    Nice read...keep it coming dude.
    Welcome to the jungle we've got fun and games.
  19. #68
    Jul 2011
    ARP bolts arrived today from USA
    C20XE ARP head stud kit ARP Part Num 209-4301
    C20XE ARP rod bolt kit (Pro Series) ARP Part Num 209-6003
    C20XE ARP flywheel Bolt kit ARP Part Num 209-2801
  20. #69
    Jul 2011
    will be interesting to see how this looks on the roof of the Manta
  21. #70
    Jul 2011
    finally got round to tapping out the cam cover to blank off the breather pipe connection not needed when running carbs.
    Rather than use a nut and bolt I drilled out to 6.5mm then tapped out M8x1.25 used stainless steel dome head alan key bolts with thread lock
    these can now go to be blasted and HCP coated, the coating will go over the bolt head.
  22. #71
    Jul 2011
    my engine is still with the engine builder, should get it back next week now that this has arrived from the UK
    one serious head gasket, I can see now why the cost so much.
  23. #72
    Jul 2011
    20XE short block back from engine builder today.
    Block acid cleaned & crack tested
    Core Plugs Replaced
    Rebore Block to 87 dia
    Polish Crank
    Hone Tunnels
    Plug Crank Sensor opening in block with core plug machined to suit (see last picture)
    Machine con rods for ARP bolts
    New Main Bearings
    New Conrod Bearings
    FORGED PISTONS, ACCRALITE, FLAT TOP
    Lighten Flywheel
    Set up and Balance Complete Engine
  24. #73
    Jul 2011
    just about there, should get the rocker cover and belt cover back from HPC this week
  25. #74
    Jul 2011
    the 120amp alternator I am using has a 10mm bolt hole, the standard alternator bushes are holed 8mm
    easier to get some split bolt through bushes run up than try and find replacements (possibly Powerflex for Saab 900?)
    anyway here is the plan, these are designed so there wont be a washed on the inner side of the bush between the alternator and the bush.
    also sorted out a rose jointed adjustment bracket for the top mount, will post pics of that later
  26. #75
    Jul 2011
    Out of a Honda Integra I picked these up for around 200 quid your money then spent the day getting them clean, they have come up well, might need to replace the bolster foam at some stage tho.
    amazing what a pressure washer, persil granules and a commercial wet vac can do
    I am hoping they fit in the Manta, the shoulders look a bit wide but got to be worth buying as I am sure I could sell them now cleaned up and make a profit.
    need to source the red materials for the rear seat if they do fit
