What system?
Results 1 to 12 of 12
Thread: What system?
    Nov 2000
    Reading Berkshire
    Vectra GSi & GTE 16V
    Unhappy What system?
    ok I have a top of the range Clarion head Unit and a 12" sub and JBL speakers under my rear shelf with standard door speakers and tweets. Question is what amp do I buy with how many channels and crossovers?
    Also whats the best way to run this little lot?
    Im not after excessive Booming but a quality sound is a must.
    Sep 2000
    Oxfordshire
    MY03 S3 Quattro
    In an ideal world........ based on a 4ch amp
    You will probably find you will need to upgrade the fronts, as they wont be able to compete with the 6x9's/subs.
    front components ( preferably new, with their own crossovers) on amp, if standard, still on amp, But start with the absolute minimum setting.
    6x9's fed from headunit
    sub bridged across the remainding 2 channels of the amp
    This is known as running the amp in Tri-mode
    Nov 2000
    Reading Berkshire
    Chers for that.
    So im basically looking for a 2 channel amp and running the fronts of that with the sub bridged?
    Sorry if im being thick I dont know a great deal about ICE yet.
    Sep 2000
    Oxfordshire
    MY03 S3 Quattro
    4 channel mate.
    ie
    Front L
    Front R
    Rear L + R channels bridged.
    "bridged" basically is joining too lower powered channels together, to make ONE more powerful one.
    If you run it this way, you will need to buy a BRIDGEABLE amp. Most amps are. But check.
    That is pretty much the best way to connect it. You wont need the 6x9s on an amp or it will be too biased to the back.
    Feb 2001
    Edinburgh.
    Vectra GSI
    OR, you could run it all off a 5-channel amp. There are several about to choose from. 2 front, 2 for the 6X9's and a separate sub channel.
    I would agree that you really should change your fronts as they would have a hard time keeping up with the rest of the system.
    Point of order, Tri-mode is when you run three channels from a two channel amp (left + right + sub bridged between the two.)
    Try before you buy.
    Chameleon.
    CHAMELEON
    Nov 2000
    Reading Berkshire
    IM EVEN MORE CONFUSED NOW
    Try before you buy.
    ER WHERE?
    I will get there hehe
    May 2001
    Shropshire
    Corsa 1.6 16v Sport
    U can get a good idea of some of the best audio componants in action at your local Halfords, aslong as it has a Ripspeed section.
    I work for Halfords and there always helpful 2 a customer that they believe to be genuinly intrested in items, so aslong as ur not a button pusher (which ur not ) they'll be more than happy 2 help ya!
    Feb 2001
    Edinburgh.
    Vectra GSI
    Try any local car Hi-fi store. There should be one near just about everybody try to listen to some demo or customers cars. Failing that get yer ass along to yer local cruise, talk to people, talk to yer mates, listen to their systems. Most of all, use yer ears, it's what you think sounds the best that matters. Whereabouts are you?
    Chameleon.
    CHAMELEON
    Nov 2000
    Reading Berkshire
    erm completely the opposite end of the country from you chap:lol:
    Im in Reading and have to go to Kleises on Friday to get a live problem sorted on my head unit so I will ask then.
    Cheers again.
    Sep 2000
    West Country
    If you happen to come over to Gloucester I will show you around my install and how its put together, wired in and importantly how it sounds.
    As you get older the toys just get more expensive.
    Nov 2000
    Reading Berkshire
    Cheers Rob I may take you up on that.
    Sep 2000
    Oxfordshire
    MY03 S3 Quattro
    Mavv you could always pop up to Oxford.
    I buy all my stuff from Oxford Car Audio their well known internet based sister company is
    Car Audio Direct.com
    highly recommended.
