Old 07-04-2003, 15:41   #1
Drives: Astra Gsi, Omega MV6
big 1 or 2 channel amp
I've just got rig of my old two 12"'s from my car and have fitted a 15" atomic instead. Its rated at 1000w (rms) and about 2500w (peak). I've been using an alpine v12 600w (t707) for a couple of days which runs it ok but has not got the power to push it hard. Anyone know any powerful amp's on a bit of a budget or secondhand. It only needs to power the sub as I have seperate amp's for all the components and 6x9's.
I've been running the sub bridged to get every last bit of power out.
Cheers
fastcarmaniac is offline   Reply With Quote
Old 07-04-2003, 18:01   #2
Drives: Cav Turbo
How about a Resonant Engineering RE35-1D, it's a mono amp, and it gives out 1100w RMS @ 2ohm and 1500w RMS @ 1 ohm, and it costs £350.00. I use this amp in my company demo vehicle, very good value. I am guessing your sub is a DVC? If not this amp might not be what your looking for.
Paul
Car Zone is offline   Reply With Quote
Old 07-04-2003, 18:12   #3
Drives: Pug 106 Quicksilver
Here you are mate have a look on this web site. I don't know weather it's too expencive or not but there stuff is real cheap you might find what your after.
ICS
NickGSI is offline   Reply With Quote
Old 07-04-2003, 21:22   #4
its only a single voice coil, so need a big mono amp or slightly smaller 2 channel un
Old 08-04-2003, 09:25   #5
Drives: Cav Turbo
Is it a single voice coil 2ohm or 4ohm?
The reason I ask is most mono amps are made to perform best with 2ohm or 1 ohm loads. So if it's a 4ohm SVC you will be best looking for a 2 channel amp that is 4ohm when bridged.
I think this one would do the job nicely....
Rockford Fosgate Punch 801S
2 x 200W RMS (4 ohm)
2 x 400W RMS (2 ohm)
1 x 800W RMS (4 ohm)
Price (Inc. VAT & Carriage): £419.99
The price shown is from Car Audio Direct
Rockfords amps are always under rated too, so I would be surprised if that amp isn't closer to 1000W RMS when bridged.
But if it's a 2ohm SVC the Resonant Engineering one I mentioned above would be great.
Paul
Old 09-04-2003, 09:37   #6
SHould be a 4ohm
Best get saving!!!!
Cheers
Old 09-04-2003, 10:26   #7
Drives: Cav Turbo
No problem
Try and get an amp second hand if money is tight, try the classifieds forum at Car Audio Direcft from the link I gave. They have some real bargains at times.
Paul
Members: 43,196
Threads: 310,554
Top Poster: LEE69 (43,147)
Welcome to our newest member, clean c
