Subs humming
Results 1 to 7 of 7
Thread: Subs humming
    MIGClub Member MattJ's Avatar
    Oct 2001
    Kent
    Toyota Celica GT4
    Unhappy Subs humming
    Hello,
    My subs are starting to piss me off! All they do is hum (picking up engine noise), how can I stop it? I think it may have something to do with the earth on the amp? Can't see why? Good thick earth cable ground to a good place! How can you tell if you have a suppressor on you alternator? what does it look like?
    Many thanks,
    MattJ
    Aug 2001
    High Wycombe
    mk1 mr2 & V8 disco
    check all the earths thats probably the problem
    Sep 2001
    Huddersfield
    Calibra 4x4 Turbo
    Do the RCA Cables run down the same side of the car as the Power Cables for the amp ??
    This is usually what causes the amp to pick up Interference.
    The solution is to run the power down one side and the RCA's down the other - Takes longer but it's the right way to do it
    Hope this helps.
    Oct 2001
    Kent
    Toyota Celica GT4
    Hello, thanks for the reply's.
    The power cable (direct from battery) does run down the same side as the RCA's. To tell you the truth this has always been on the back of my mind that this is the cause mmmmm. Is there anything on the driver's side that can cause interference if I put the RCA's down that side?
    Thanks,
    MattJ
    Sep 2001
    Huddersfield
    Calibra 4x4 Turbo
    I usually try and run the RCA's down the side with the least standard wiring, but I don't think it matters.
    I don't think there is enough current in the standard wiring to cause interference, but I might be wrong. I'm pretty sure the the major interference source will be the Amps's power cable.
    Oct 2001
    Kent
    Toyota Celica GT4
    Talking
    Thanks,
    I will give it a go over the weekend. See what happens!
    Cheers,
    MattJ
    Sep 2001
    rainford
    astra mk4 sport
    Exclamation
    ps there is nothing wrong with the sub it is the amp i have my amp in front of me coz i had the same problem and then the whole thing just blew so far i have found that my input wires have burned out and also somehow my output wires to the speakers must have gotten crosswired coz the neg on the board have burnt out now i cant get the damn thing loud without it cutting out then fuzzing
    ps i wrote in ages ago woundering what was up and know i know in other words the damn thing is fecked so if i was u i would not use it till uve sussed the prob otherwise ur gonna have a lot of mony down the drain
    l8r -al-
