ive got a sony 6 disc changer and wondered where i cud put it, it needs to be pretty unmoveable as a lot of things go missin out of my car where i live...!
i thought it wud be a good idea to put it in the gap above the glove box and make two bars to go across the front. but the changer dont go all the way back in the hole.
it doesnt fit in the glove box itself either...
has anyone else had a good idea with there changer???
i have a 6 disc changer in mine mounted behind the dash level with the glovebox i had to cut a hole in the dash behind the glovebox door to get to it
it sounds awkward but is really quite easy to use and very well hidden
Take passenger seat out bolt it under there,not too far back as rear passengers can't get their feet under.
Can't nick it cose thay'll have to take out the seat if you put it in properly,also you can change the discs incar than going in the boot
i used to have my 6 disc changer under the passenger seat and it works really well as it was hidden , easy to get to from the drivers seat and you can still use the glove box to put all your crap in
