Autowatch Alarm wiring help - Calibra
Hi Guys,
Currently have an Autowatch RLI160 setup in the cali. It's been there since I got the car. It has alway made a sound when arming and disarming but no visual indication. The sound was getting a bit annoying so I've disabled it. I tried to wire up the alarm to enable the indicators to flash when arming and disarming but nothing is happening, the alarm does what it should but the indicators don't flash. I did notice that in the past someone has connected something to the brake circuit so I done a temp job and connected my alarm to the brake circuit and the brake lights flashed when the alarm was armed and disarmed, so this proves that the alarm is working but don't know why it isn't making the indicators flash? I believe the indicator wires are black/green and black/white. Also I can remember someone saying that you can wire an aftermarket alarm to the existing vx alarm which is located behind the glove box, there's also supposed to be a connector of sorts but can't locate it. Any help is much appreciated
Cheers
