Corsa c hu won't turn of with ignition
Results 1 to 9 of 9
Thread: Corsa c hu won't turn of with ignition
    Jan 2009
    scarborough
    Hi I've just brought a corsa c and the standard hu won't turn of with the ignition does any 1 no why this is thanks
    Jun 2005
    The Isle of Man
    1.3 Chevette L
    Re: Corsa c hu won't turn of with ignition
    What model head unit is it?
    Jan 2009
    scarborough
    Not sure m8 were does it say
    Jun 2005
    The Isle of Man
    1.3 Chevette L
    On the front. CDR-2005, CD 30?
    Jan 2009
    scarborough
    It's cd 30 m8
    Apr 2005
    Derby
    Way too Fast :-/
    Do you mean after you remove your key or just turning the engine off.
    Back of ignition switch is the switching for stereo iirc. It is all one unit though, might just need some spray grease down the ignition
    Jun 2005
    The Isle of Man
    1.3 Chevette L
    Go through the settings and make sure the "Ignition Logic" setting is on.
    Jan 2009
    scarborough
    It's when you take the key out the stereo stays. on and cheers m8 I'l have a look through the settings
    Jan 2009
    scarborough
    BigDave1979 it was the ignition logic settings m8 thanks for your help.
