Double Din to Single Din
Ok guys, i have a Astra H 150 CDTI...stereo system is currently standard, I have done a few mods to the exterior and now thought id spend a bit of time on interior, i was thinking of starting with the ICE, however before i wasted too much time researching etc i thought id ask on here whether anyone has replaced the standard double din stereo with a single din setero and if so how much effort this was!
Any input would be great!
Re: Double Din to Single Din
All u have to do mate is buy a blanking plate for it buddy
As above, a suitable fascia adaptor plus a suitable wiring harness and optionally, but reccommended, a steering wheel remote interface to retain the existing controls - important if you have the trip computer as you lose access to it when the stock head unit is removed unless you use an adaptor that will control it.
Companies like autoleads and connects2 supply pretty much all you need. A lot of their products are available off the shelf in the likes of Halfords etc.
pop down ur local halfords or maybe look online for a car audio company either should be able to supply a fascia like stated before.
In my Polo, I had a double din unit, and changed to a single din Pioneer unit, when I researched online, models with a single din head unit have a cubby hole below, so I sourced a single din cubby hole from a breakers yard. This could be the case for you. I cant remember if the double din's in the newer astra are trapezoids, if thats the case you may need to buy an adapter plate, Halfrauds do them for around £20, or companies on ebay do them for considerably less
VAUXHALL Astra H 2004> CD Stereo Fascia Panel CT24VX05 | eBay
Other colours are available, just the first one I found, just search 'Astra H Fascia', thats all I done
