Corsa aerial lead
Corsa 1998. Need to replace radio aerial lead as plug has come off radio end. Are there any joints in lead? and if so whereabouts? Which way does lead run to the aerial at back of car?
Re: Corsa aerial lead
I was just looking into this yesterday. The aerial lead runs from the radio, under the glovebox in the loom clipped to the edge of the dashboard and there's a join under the passenger side kick panel. If you want to replace this short section you'll have to get one from a scrapper as it's no longer available from Vauxhall - only full length single piece leads are available now.
Thanks for quick reply will have a look tomorrow. Got a new lead from Halfords its a bit long and it cost a but much but will reach to the join ok.
Thanks again.
