coding the radio on a 2004 vectra
Results 1 to 4 of 4
Thread: coding the radio on a 2004 vectra
    May 2011
    Hi folks im new on here and im wondering if someone could give me a bit of advice. My batterey was changed and now my radio has went into safe mode. Iv no code for it plus even when i follow the instuctions of holding in the as button there is no beep. is there a standard code.
    Oct 2000
    Sunny Milton Keynes
    Bmw 3 series
    Re: coding the radio on a 2004 vectra
    Standard 'code' would be to search first.
    Jun 2000
    Hampshire, UK
    Vectra SRi
    Hi
    There is no standard code, if you do not have the code you can go to Vauxhall and get the code but you will need your V5 as the keycode contains information about the radio and keys and immobiliser etc.
    When you have the code you need to turn the ignition on, then turn the radio off.
    now press and hold the AS Button and turn the radio on.
    you should then hear a beep and have the opportunity to enter the code using buttons 1-4 pressing them the number of times to show the code on the screen
    Then press and hold the AS button until you hear another beep and the radio unlocks.
    Tom
    Jun 2005
    The Isle of Man
    1.3 Chevette L
    The radio code is on the "Car Pass", which should be in the folder with your manuals and service book etc. It's a credit card sized piece of thin-ish card. If you can't find it, Vauxhall will replace it as Tom says.
