Is this Corsa C Or Corsa B Wiring?
Results 1 to 4 of 4
Thread: Is this Corsa C Or Corsa B Wiring?
    Mar 2009
    Coventry
    Im looking to wire up an alarm on my corsa c combo van.. I know the wiring should be the same as the corsa c, as everything else is pretty much the same.
    Been looking for a wiring diagram online but cant find anything other than this, however it doesnt state if the wiring is for the corsa b or c....
    Im hoping it might jog someones memory, as im sure someone on here has fitted an alarm themselves.
    Apparently the wiring is found behind the glovebox...
    12V Supply THICK RED WIRE AT REAR OF GLOVEBOX IN LOOM TO O/S.
    Ignition Supply BLACK/PURPLE WIRE AT REAR OF GLOVEBOX IN LOOM TO REAR OF CAR
    Earth Points AT MAIN EARTH POINT (AND/OR) AT SEPARATE EARTH POINT
    Direction Indicators
    Indicator Lamps BLACK/GREEN WIRE AT REAR OF GLOVEBOX IN LOOM TO O/S. (AND/OR) BLACK/WHITE WIRE AT REAR OF GLOVEBOX IN LOOM TO O/S. (negative)
    Earth Contacts
    Bonnet FIT PIN SWITCH
    Doors GREY WIRE AT REAR OF GLOVEBOX IN LOOM TO O/S OR AT INTERIOR LIGHT OR N/S PIN SWITCH (negative)
    Boot/Hatch BROWN/WHITE WIRE IN N/S SILL HARNESS TO REAR.
    Immobilisation
    Immobilisation - Starter BLACK RED WIRE AT REAR OF GLOVEBOX IN LOOM TO O/S.
    Immobilisation - Fuel BLUE/RED WIRE AT REAR OF GLOVEBOX IN LOOM TO REAR OF CAR
    Central Locking
    Central Door Locking Type Multipoint Negative
    Lock Wire THIN RED/YELLOW WIRE AT REAR OF GLOVEBOX IN LOOM TO O/S.
    PULSE ONCE FOR LOCK, TWICE FOR LOCK AND DEADLOCK
    Unlock wire THIN RED/BLUE WIRE AT REAR OF GLOVEBOX IN LOOM TO O/S.
    PULSE ONCE TO UNLOCK O/S/F DOOR, TWICE FOR ALL OTHER DOORS.
    Anyone got a clue which corsa its from? Cheers
    Jun 2003
    West London
    Coupe turbo
    Re: Is this Corsa C Or Corsa B Wiring?
    That will be a Corsa C going by the deadlock wires
    Apr 2010
    southport
    2008 civic diesel
    corsa b's have dead locks buddy, but it is from the corsa c, the b's dont have a bonnet switch...
    Jun 2003
    West London
    Coupe turbo
    The info's saying fit a bonnet switch
    I know the Corsa B has deadlocks but they are mechanicaly operated where as the C is electronic
