Scottish Regional Co-ordinator/MIGWeb Moderator
Astra vxr h/u replacement?
Hi, wanting to fit my pioneer single din h/u into my 56 plate vxr so i can use the usb input, and my sub/amp again (i have the h/u, sub amp, wiring kit, and facia adapter)
Ive heard this can cause problems due to the std ecu being speed sensitive? (ie volume increases with speed) A "friend of a friend" has alot of trouble with his corsa vxr after swapping h/u.
Has anybody fitted after market head units into vxr's?
Cheers
