Fuse for the stereo keeps blowing
Results 1 to 17 of 17
Thread: Fuse for the stereo keeps blowing
    Jan 2010
    Chepstow
    Corsa GSI XE/ C16XE Corsa
    The fuse keeps blowing when I get to a certain speed any ideas?
    "It's not about what you can BUY, It's about what you can BUILD!"
    Jun 2010
    aberdeenshire
    escort van :P
    Re: Fuse for the stereo keeps blowing
    what rating of fuse is it ? mayb try one slightly higher ?
    Jan 2010
    Chepstow
    It's already a 30amp It hasnt done it for a couple of hours but I will keep an eye on it
    Jun 2010
    aberdeenshire
    escort van :P
    30 amp for a sterio :O is it ment to be that ?
    Dec 2001
    Southampton/Reading
    No longer The Pheonix
    Have you checked all the wiring is correct? Maybe a bad earth?
    Jun 2002
    Wrectum
    Shuvit, e36 track car
    30amp!! lol.
    Does it happen when you rev the car up or literally when you drive fast? If revs it's possibly the voltage regulator in the alternator. Try and get a multimeter on the live to ground and check the volts.
    Northeast Kent
    Quote Originally Posted by Tathan View Post
    30amp!! lol. .
    lol. next fuse up is a paper clip.
    Jan 2010
    Chepstow
    It controls the interior lights as well, I'll check the alternator haven't tried reving it it's when I hit about 70
    Jun 2002
    Wrectum
    Quote Originally Posted by DarrenH View Post
    You dick, I need to remove cider from my keyboard.
    Nov 2004
    derby
    cav 93 sri red top
    This thread is funny in a scary kind of way lol
    This;
    Could require one of these;
    Gagged
    May 2010
    Manchester, United Kingd
    Corsa b
    More than that lol all te wires behind the cd player which would spread in to the engine
    Jan 2010
    Chepstow
    The thing I don't get there was already a 30amp in there and it's only happened since I took the fan belt off... I pit the earth back on, the only other thing I can think of is I have had to do alot of rewiring in the main loom would it be to do with that?
    Gagged
    May 2010
    Corsa b
    It could be that lol I guess one Of the terminals are earthing out matey
    Nov 2004
    derby
    cav 93 sri red top
    Quote Originally Posted by peebs View Post
    Don't you think this post should have been included a little earlier, like in post 1...
    In 95% of electrical issues its down to some person making alterations or rewiring items that they simply don't follow nor understand... Its time for you to call in an auto electrician mate....
    Jan 2010
    Chepstow
    The reason I had to rewire some things was cause the wiring to the knock sensor wasn't connected to anything the wires had been cut so all I done was solder them back together I have a new loom comin soon anyway that might cure it
    Oct 2010
    City of Bradford, United
    Corsa C20let
    haha 30 amp fook me. good slide show mate lol
    Jun 2009
    county durham
    Vectra B 2.2
    Its deffo a crossed wire as most vauxhalls have a system that turns the radio up as you drive the car above 60mph. You are deffo looking at burning your car out if your running such a high rate fuse.
