help with amp problem
Results 1 to 2 of 2
Thread: help with amp problem
    Apr 2009
    north yorkshire
    Calibra v6
    i have just installed some component speakers
    the problem im having is when the headunit is on tuner the amp is on but when i change it to cd the amp wont work and the power light goes out.
    anyone any idea's
    Nov 2004
    derby
    cav 93 sri red top
    Re: help with amp problem
    Sounds like you have connected your amps remote to the Head Units electric aerial feed... Sony units retract the aerials when you switch sources from radio to cd/aux etc...
    Check Head Units wiring for relevant colour coding, Amp Remote will be either Blue or Blue with white trace...
