Astra MK4 Key recoding?
Results 1 to 4 of 4
Thread: Astra MK4 Key recoding?
    Jan 2003
    South England
    Astra GTE 16V,
    Hi everyone,
    My buttons on my Fob stopped working so i popped in to my local Vauxhall dealers to get a new battery , and the guy said looks like its the fob, as with a new battery the LED does not light up ,
    he quoted 80 quid for a new one,
    i have seen em on ebay from 5-15 quid, how easy it it to reprogram them, i know the ford ones its just oress a few buttons and turn the ignition on and off a few times?
    can these be done the same?
    cheers
    Attached Thumbnails Attached Thumbnails Astra MK4 Key recoding?-astra-key-jpg
    Jan 2010
    sheffield, yorkshire
    MK 2 ASTRA C20XE
    Re: Astra MK4 Key recoding?
    the thing with vx remotes are the connections on the small circuit board are known for breaking or the solder joints comin loose, id be having a look at those first, try taking the board out of the remote and squeezing the battery holder onto the board and press the buttons at the same time, i think you will find this will work, then to reprogramme the lock/unlock function of the remote put the key in the ignition and turn the ignition on and press the lock and unlock buttons a few times, that will re-programme the remote into your car!
    ian
    Jan 2003
    South England
    Astra GTE 16V,
    so if i buy just the button part, i can recode this myself easily?
    thanks
    Jan 2010
    MK 2 ASTRA C20XE
    i dont know weather it will work on a new key, as yours is already hard coded to your car, might need a tech2 to programme in a brand new one
