corsa door locks
i thought i had sorted out all the problems on my corsa until i went to open the p/s door, it wont open from the inside or out side but the snip is up, how do i get this door to open plz help , many thanks
Re: corsa door locks
sound like onr of the bars on the lock has popped off,if you can get the door card off should be able to see the bar and clip it back on should sort the proble,altho not sure if you can get the door card off with the door clsed
its very difficult, but is doable, i've done it on a 5 door car, similar problem, and also wouldn't unlock plastic clip had snapped so the bar works its way out.
