Hey, for you solder junkies I thought it would be interesting to post a simple immobiliser schematic which I designed a while ago.
I used this in several of my cars and found them a few times with a broken door lock, broken tupperware around the steering wheel and broken lock/stripped and cut wiring...BUT at least it was still there!!!
The schematic at the bottom proposes a bypass in the connection between the crankshaft sensor and engine control unit pins 47 and 48, which is a good choice for a car with a red top engine. Do keep in mind this connection is made with shielded wire though... Whatever connection you want to cut between your engine and the control unit is up to you off course, that makes it harder to figure it out for any regular car thieve. To test your choice just pull some plugs under the bonnet and see which one prevents the engine from being started. Or as a professional... Just keep in mind the current rating of the relay contacts... As an activate/deactivate button you can even place hidden or combined switches which are impossible to figure out for those who don't know. You could even use coded switches or key lock switches, hidden magnetical reed contacts...whatever, I'd say BE CREATIVE!!
The system could work as follows:
You turn the ignition key to make contact, then you need to operate the switch which will connect any bypassed connections between the engine and control unit. The engine starts.... Then I have incorporated a time delay which will keep the connections in tact for a few minutes so if you want to make a short quick stop (to adjust your GPS or whatever, write an SMS..) you don't need to re-activate it, engine still starts..
If you are going to leave the car for longer anyway and want to activate the immobiliser right away then press the same button with the ignition key off and the system will activate right away, without delay...
I have included an LED which will be lit for as long as the delay is activated, it will only be lit when the ignition key is off. After the delay time when the light is out the car won't start until the button is pressed...
The circuit draws no power when the car is parked and the delay time is passed, when the button is pressed it'll draw just 160mA!!
Car thieves, eat that!!!
Here's the schematic:
