Help: Removing window winders on doorcards?
Results 1 to 12 of 12
Thread: Help: Removing window winders on doorcards?
    Oct 2009
    Scotland
    Astra MK3/MK4
    Changing the doorcards on my mk3 astra, cant get the window winders off though? Not keen on snapping them as the i'll need them for the new doorcards. Anyone got any techniques to taking them off?
    Feb 2007
    fife
    corsa sport + GSi
    Re: Help: Removing window winders on doorcards?
    There's a little clip on the back of the handle needs to be pulled up, kind of looks like this (^) cba drawing it lmao
    sure you need the handle pointing downwards and hook it from above, or might be able to push one side up from underneath.
    Dec 2005
    UK
    Frontera LWB, Astra GSI
    Get a small hook or flathead screwdriver under the winder and flick the clip off underneath.
    The winder is pushed onto a spline with a groove in it, and the clip fits in the groove and stops it from coming off. Genius and simple.
    Oct 2009
    Scotland
    Astra MK3/MK4
    awryt, will try that later on! thanks
    MIGWeb Moderator
    Midlands
    Nowt
    Jun 2008
    Stamford, Lincs
    C16SE + X16XEL Mk3 Astra
    Sod buying a tool :P
    I just push the door card back, get a little screwdriver in there and it pops straight out!
    C16SE • Cruise Control • GSi Trip Computer • 4-2-1 Manifold • OEM+ Interior • Apex -40mm Suspension
    Oct 2009
    Scotland
    Astra MK3/MK4
    sounds alot easier than it is haha, still not got them off. will buy the tool at this rate, is the clip up tight to the window winder or is it in the doorcard?
    Its up tight to the winder, push the card in and the lower washer and you should just see the clip. Carefull it will ping right with some power..
    Apr 2010
    southport
    2008 civic diesel
    will be up against the door card buddy, there is about 5mm between the winder arm and where the clip is.
    Oct 2009
    Scotland
    Astra MK3/MK4
    thanks guys, will give it a try tomorrow and see how i get on!
    Oct 2009
    Scotland
    Astra MK3/MK4
    got the doorcards off today and fitted uprated speakers, thanks for the advice everyone.
    got the winder off by jamming a rag between the doorcard and window winder and pulling it out
    Jun 2010
    St Helens
    Astra Mk4 1.8
    Best way I have found to do it, Is to use a cloth.
    Basically roll the rag up and slide it behind the winder and lower it to the bottom. Make sure the pointed ends are touching the rag and move from side to side. It should pop up enough for you to get hold of it and pull it up.
    Cheaper than buying any tool and works just as good!
