Results 1 to 4 of 4
Thread: Connects2 CANBus or Kenwood CANBus adaptor?
    Dec 2004
    The Granite City
    MK5 Astra SRi CDTi
    I'd like to fit a Kenwood Headunit to my Astra H but am not sure which CANBus adaptor to get.
    I have to get the facia panel, an aerial adaptor but do I get the Kenwood CANBus adaptor or the Connects2 adaptor. Are there any differences between the two?
    I've read that after changing headunits, you will no longer be able to adjust the system clock or date. Would either of these adaptors still allow you to change this?
    It's an Astra Design if that helps.
    Thanks.
    No Text-Type on MIGWeb please. Leave it for mobile phones, where it belongs.
    Jun 2005
    The Isle of Man
    1.3 Chevette L
    Re: Connects2 CANBus or Kenwood CANBus adaptor?
    I'm pretty sure the Connects2 adaptor has functions built in for the BC/MID, but I remember their array of products left me unsure of what exactly to purchase, but I definately remember instructions for operating the BC and changing settings using the steering wheel buttons. I didn't bother in the end as I sold the car on anyway.
    Best bet is ask the manufacturers for a definitive answer if you don't get a positive reponse here.
    Dec 2004
    The Granite City
    MK5 Astra SRi CDTi
    Thanks for the reply BigDave1979. The Autoleads adaptors are cheaper but the Connects2 adaptor gives ignition live, speed signal, illumination wire - not sure if the Autoleads or Kenwood CANBus adaptors do this.
    Has anyone here fitted any of these to their Astra H's?
    Thanks.
    Jun 2003
    West London
    Coupe turbo
    The connects2 adaptors do allow you to get back into the setting on the display to change the clocks. It also gives out a ignition feed and probably other things too
