hi there im new too all this and ive just brought 3 15inch subs 1 being mutant 1 being jbl and the other mmates i jus need to find out what dimensions the box for them should be as i want too make a wall but just need some help manythanks
Please don't title threads "help please", it gives no idea what your questions are about. You will find you'll get many more views with a title describing the problem.
They're there, in their room.
You can't just ask for sub box sizes without any information.
Subs come with a whole bunch of specs that are needed to calculate the volume correctly.
google each brand and model number, there will be a spec sheet to tell you how much volume you'll need and wether to port or seal it.
Hi mate, welcome...
If your gonna be building a wall, I would recommend you use similar subs.. Using multiple brands is a bad idea, as using different sizes is... First job is to work out how much enclosure volume you can attain in your car, then select your subs in accordance with this... I would suggest going ported, but you must ensure each sub is equidistant from the port to avoid loading differences.. A single enclosure will offer the best results, but due to size internal bracing will be needed.. When selecting your subs you will need to ensure you get the correct coil configuration & impedances to present the optimum load for whichever amp/amps you decide to use..
Once you have decided on all the above you will need to ensure your charge circuit & power supply are upto the proposed demand, this area can swallow a huge chunk of your overall budget....
Post up proposed budget & car make/model/type...
Will check out your options from there....
subs.
jbl gt4 15inch 1000w
mutant MT1507X - 15” 800w
mmats juggernaut 15inch 1400 Watt RMS
amps
Kenwood KAC 9152D
kenwood kac9104d
fli 900s
ok so i listened too wallopsri and decided to swap the mmats sub and and mutant for 2 12inch jbls soo now i have 1 15inch jbl 1000w and 2 12inch jbl 1000w but i still need ideas off how to lay it out in my car and sub box dimensions i really need help guys![]()
ye im not worried about weighing the car down i jus love big bass but thanks for the idea![]()
Just turn them ovet and draw around them then go in acouple of mm and go round that that'd what I did with 6x9s or go online and search them
i'de just use the mmats, they're well rated drivers. make a box that is around 4 cuft and ide tune the port between 28-33 hz but it depends what music you listen to..i listen to dubstep, DnB and hiphop. if your listening to punchy club music tune it to around 40-45 or even sealed. i ran 2x12" pioneer tsw-3004 subs which were sat in 2x 1.3 cuft boxes tunned to 28Hz. this got me a healthy 147.8 db @ 31Hz. all depends what amp your running to, dont go for budget amps that state 2000w max power..they dont and they maybe got that that rating for 0.5 seconds running 18v throught them. with just a normal charge system @ full volume u'll be looking at around 12-13V if your lucky.. look just for RMS figures and ull be on the right track. use that one 15" witht the right amp and box you will be very surprised. if you want a box designing give me a PM ide be happy to help
heres a couple pics of my system not too pretty but f**king loud
and zero guage wiring
bit of inspiration, a picture of a friends setup in a chevvy blazer. 6x18" subs in a clamshell box design hitiing over 152db at around 20hz. its killed two windscreens allready
ASTRA G C20XE,BUILT NOT BOUGHT... GD DEVELOPMENTS
