Quick question (What Watts)
Results 1 to 6 of 6
Thread: Quick question (What Watts)
    Feb 2002
    North London
    EP3 Civic Type-R
    Havent been in to car audio for ages! Lost a lot of the knowledge i used to have (pushed out by new stuff no doubt!)
    Anyway, If an aftermarket Headunit has 4x45W output, would it run a set of components nicely that have an RMS wattage of 70w?
    Are Headunits advertised with their RMS or Peak wattage?
    Obviously running the comps with an amp would be the best plan, but would they sound good if they are run using the head unit only?
    Cheers
    Keeping it Real
    - MigWeb's Undisputed Street Fighter III 3S Champion -
    Feb 2006
    Berkshire
    Astra mk3 1.4 est.
    Re: Quick question (What Watts)
    Somone's bound to disagree with this, but here goes.
    In real world, RMS is worked out by putting a sine wave into a speaker and calculating the "Root Means Squared" component i.e. the RMS figure.
    However music as we know is not an exact sine wave and calculating this is not easy. (I've put a brief explanation below)
    Peak power also sometimes rate MUSIC POWER I've found is usually a better way to work out WIKI has a good article on it here
    Audio power - Wikipedia, the free encyclopedia
    OK in the real world the RMS power rating of the amplifier should be as close as possible to, but not exceed, the power rating of the speaker. By using as powerful an amp as safely possible, the risk of driving the amplifier into clipping is reduced, thereby ensuring that the speakers will receive clean undistorted power.Simply stated: clean power - GOOD, distorted power - BAD.
    Amp/speakers power question
    {source: Cerwin Vega}
    Distortion kills speakers !
    HTH
    ‡If the waveform isn't a pure sine wave (like a square wave or a signal with mixed sine waves of different frequencies or music), multiplying the peak times .707 will not give an accurate RMS value and therefore will not give an accurate indication of the work that the waveform can produce when driving a load. For more complex signals, you need a meter that will calculate the RMS value from a set of samples taken at regular intervals.
    In common use, the terms "RMS power" or "watts RMS" are erroneously used to describe average power. A 100 "watt RMS" amplifier can produce a sine-wave of 100 watt average into its load. With music, the total actual power would be less. With a square-wave, it would be more.
    Quote Originally Posted by MasterWu View Post
    Cheers
    THAMES Valley Porsche Club
    Astra Mk.3 1.4 GLS Estate
    944 S2 Cabriolet ( 208BHP / 211ftlbs )
    Feb 2006
    Berkshire
    Astra mk3 1.4 est.
    so to answer the question, yes it will no problem ... BUT.. at higher voilume levels it will distort, the distortion has a DC component, DC into a AC speaker = BAD, bear in mind that 45watts RMS, WONT actually put out 45watts, could be more, usually less.
    and all speakers/head units will state RMS, PEAK and somtimes MUSIC or TOTAL POWER,
    Cheers
    Dom
    Dom is offline
    MIGClub Member Dom's Avatar
    Sep 2001
    Northants
    73bhp MK4 Astra POS
    Converting RMS to peak is pretty easy.
    Take the RMS power, multiply by 1.41 then add some random number between 100 and 10000 and you have your "peak power" lmao
    Feb 2002
    North London
    EP3 Civic Type-R
    Thanks for the replies!
    Keeping it Real
    Feb 2006
    Berkshire
    Astra mk3 1.4 est.
    Yes but that only works on a PURE wave i.e. SINE or SQUARE,
    music is NOT a sine wave
    Quote Originally Posted by Dom View Post
