vibe a7 amp powering up but no sound ?? :/
i have 2 vibe a7 amps i've used them before and took them out the car a while back ater getting them back over rom ireland only one seems to be working
the set up as follows
0 guage positive from the battery to the boot into a 4way splitter
0 guage negitive from seatbelt buckle into a 4 way splitter
both + and - 4 guage going from splitters in to both amps
1.5mm household wiring for remote (cdplayer - one amp then one amp to the other )
im getting both amps powering up (blue led) but sounds only coming out amp one
i've tryed and double checked my wiring and even checked with another amp i have and the sub works fine and the wiring is not as fault
also checked the fuses and replaced them just incase
has any one had problems with these amps i dont know if storing them mabe the damp has got into one but i thought it'd get into both if that was the case
and does anyone know any repair shops in glasgow area
any help would be appreciated guys
thanks
Re: vibe a7 amp powering up but no sound ?? :/
send it back, sounds like its been cooked
