Mk 4 Astra Gsi Alarm
Got a problem with my alarm, when I press the keyfob the first time to lock the doors, it works fine. Then when I press the keyfob the second time to activate the immobiliser and alarm, nothing happens, I tried putting the key in the door like the manual said but that won't work either. Anyone got any idea what could be wrong?
Re: Mk 4 Astra Gsi Alarm
Dodgy drivers door pin switch or badly wired afterarket stereo
Check bonnet switch all switches will stop deadlock and alarm set as alarm thinks some door etc is open
Ian
