Will These Speakers Fit A Corsa B?
Results 1 to 5 of 5
Thread: Will These Speakers Fit A Corsa B?
    Mar 2010
    Hi. Does anyone know if these will fit in the front doors of a corsa B?
    http://www.halfords.com/webapp/wcs/s...Id_165707#dtab
    thanks
    Feb 2009
    London, Middlesex
    Corsa LS
    Re: Will These Speakers Fit A Corsa B?
    Unfortunatly thoes will not fit directly into the door of a corsa b, because the screw holes in the corsa' doors are in a triangle shape not a square. However as most/all new speakers have this arrangment there are adapters you can buy, which you screw the speaker into then, the adapter with speaker to the door.
    Vauxhall Corsa B/C 93> 130mm Front Speaker Adapters on eBay (end time 23-Apr-10 00:28:25 BST)
    Above is an example, when ordering make sure it will fit you speaker size
    No messing around, Get a Corsa 5 door
    Dec 2007
    Not only do you have an issue with the screw arrangement, you will also find if you try to fit them straight into the original holes, that you won't be able to lower your wondow fully without lots of noise and bits breaking :S
    As Collateral advises, those adaptors work a treat, have them fitted in the front of my Sport for almost a year now, easy to fit, brill fit and finish, looks very professional ;D
    Oct 2009
    birmingham
    do what i did mate take out the old speaker and snap the speaker out of it and use the bracket and fit your new speakers in jobs a gd n
    Oct 2009
    birmingham
    oh and you will have to bend the hole in your door abit bigger well thats what i had to do and then they fitted sweet, but i thought that was a gd idea tbh mate lol i was well chuffed lol
