have my meriva probably around a month or so now, i wanted to reset the ecu so the car is set to my driving.
i disconnected the battery, but the power sounder was going off.
what do i need to do to disable the power sounder?
cheers guyz
alan
cheers guyz
alan
turn on the ignition then off and disconnect the battery within 30 seconds of turning ignition off...
(loosen terminal first is the best way...)
Reset the ecu so it adapts to your driving?
Who told you that?
Lol......
Jack said,
Surely you are only pulling it one way though? ie. you are pulling it along its length.
Who told you that?
i read it on here...so is it aload of bollox then?
YesOriginally Posted by alan_t
Jack said,
you turn the ignition (not engine) on then disconnect the battery.
Please try and find it
It does reset the adaptive learning.
There's also an option somewhere in the ECU to do it via tech2.
Oh, and once you've reconnected the battery, go for a drive.
Highest gear, but low speed.
ok will do, as i had to disconnect the battery any way.
cheers
I need proof! LolOriginally Posted by Dav1d
Jack said,
dont see why it couldnt loads of cars do
Xbox Live! = DEATHS UNCLE
The following words in your search query were ignored because they are too common words: 9000 problem
Ok, lots of cars ecu's can adapt but not to the drivers style of driving! The ecu will adapt to different fuel types.
Jack said,
