carputery headunit info wanted
Results 1 to 4 of 4
Thread: carputery headunit info wanted
    Bishops Stortford
    2 seat 2.2 vxl
    I had my stereo removed by some kind chaps yesterday morning, so want to replace it with something as its a bit dull in there lol.
    I dont need epic sound quality/millions of speakers etc but I do want to be able to load a stack of MP3's in, play CD's, obviously RDS radio and if possible integrate DAB in there too.
    And with a tiny display that can be kept somewhere subtle, and a fairly simple interface.
    Is there anyway of doing this with a carputer style setup?
    http://slindborg.hostei.com/ Gearbox calc, Top speed, compression ratio, engine capacity, 1.4 tuning guide, Wheel offset calculator
    Fixed broken gearbox calc :)
    Jun 2005
    The Isle of Man
    1.3 Chevette L
    Re: carputery headunit info wanted
    Any particular reason for a carputer setup? There's a load of decent headunits out there that will do all that.
    Bishops Stortford
    2 seat 2.2 vxl
    Dont want a 'headunit' in the headunit place...
    Dec 2008
    ipswich
    mk3 astra estate LS
    with a carputer its simple, best thing to look at these days is one of the dual core atom based mini itx boards, about 1-2gb ram, a decent harddrive that can handle knocks while on the move (or put it on rubber grommets to help with the vibration, and a M2-ATX 12v dc-dc power supply, also put it somewhere with plenty of airflow to help aid cooling, as for a screen ive heard a lot of good reviews on a lilliput 7" touchscreen, u wont need anything like vista so win xp is best and then you will need a front end like roadrunner (?) once set up you can add a usb GPS reciever for sat nav, usb bluetooth for making and recieving calls, the list goes on and on.
    if building your on car pc seems a bit to much you can buy one fully built from a few places, google for "voombox car pc"
