AfterMarket Stereo Wont Work In Vectra???
Results 1 to 10 of 10
Thread: AfterMarket Stereo Wont Work In Vectra???
    Mar 2010
    Hey, my aftermarket stereo wont work in my 1995 vectra?? theres 3 blocks on the car, but theres only 2 open blocks on the bak of my stereo,, i tryed takin 1 of the 3 blocks, and fittin it in my stereo, but stereo still dont work?? people have said the 3rd block is only for steerin wheel controls ect.. and it shud work with just the 2 blocks, but it still dont work lol. is there like a power wire or some thing on the 3rd block i need 2 wire up to 1 of the 2 blocks??? thanks... ( o btw i tryed my mates stereo in there and still didnt work, so i know its not my stereo lol )
    Jun 2005
    The Isle of Man
    1.3 Chevette L
    Re: AfterMarket Stereo Wont Work In Vectra???
    On a Vauxhall radio loom the battery and ignition +12v positions are transposed compared to standard ISO, but it depends on what your aftermarket stereo is. Personally my preference is to fit a wiring harness from the likes of Autoleads/Connects2/Halfords etc to convert to standard ISO.
    If you're going to do it yourself though, check out the sticky on this section for the radio connections.
    Mar 2009
    WAKEFIELD
    Astra mk4 Corsa b
    Same here don't like chopping the wires looks neat with a conversion block and its quicker to fit
    Jul 2002
    Pompey
    MK3 2.0 Pineapple
    Conversion block? Every stereo I've ever owned has the ability to swapthe red & yellow wires 'built in' to it's loom, no need to any sort of block.
    Check out my sheddy Sport!
    Mar 2009
    WAKEFIELD
    Astra mk4 Corsa b
    when i say conversion block mayb i should of said harness you can get em for about 12pound u plug em into the standard vauxhall loom then the radio of ur choice no chopping of wires needed its a conversion from standard block connector to say a sony radio much neater than cutting and taping wires.
    Dec 2005
    glasgow
    astra gsi b204 saab lump
    Quote Originally Posted by astra16vcdti View Post
    agreed and safer
    u can sleep in ur car but u cant race ur house
    Mar 2009
    WAKEFIELD
    Astra mk4 Corsa b
    Quote Originally Posted by mickygsi View Post
    agreed and safer
    hate seeing standard looms chopped looks a mess
    Oct 2000
    Sunny Milton Keynes
    Bmw 3 series
    Get a jewellers screwdriver, flat blade, thin.
    Press the retaining clips on the two wires(yellow & red)
    Remove them, swap them over (bending the clips back out if need be)
    Job done.
    £12 for a harness, for that.! lmao
    Soft.
    Mar 2009
    WAKEFIELD
    Astra mk4 Corsa b
    will have to try that next time i fit a radio.cheers for advice
    Nov 2004
    derby
    cav 93 sri red top
    Sounds like a blown fuse, check fuses for;
    1, Batt Supply - Constant 12v feed...
    2, Ign Supply - Switched 12v feed...
    If Ign supply fuse is gone, then no other circuit will be affected....
    If Batt supply fuse is gone, then other circuits will be affected....
