how the **** do you remove one of these???![]()
quick answer wanted before i attempt it with a drill![]()
bump...its uglyness is hurting my eyes![]()
Argh![]()
Any luck with this yet m8! I think if u remove the plastic surround then each side there is like a little screw/rivet put little flatscrew driver and eith lift or push it down (it only goes 1 way) and pull that side of the alpine player slightly out then do same to the other side.
doesnt budge![]()
i tried using sony keys as from the look if it, the cage is the same...i think im going to have to remove the whole centre console to remove it
im just waiting for the kids to disperse then im going back with a drill![]()
get 2 flat screw drivers slide 1 in each side (inbetween cage and unit) try to pry it out shouldgo if u get 1 side the othe should just follow suit bud.
thanks for the advice
*goes to find hammer*
lol they can be bastards but they made like that 2 stop the thieves
tried the screw driver method...no go, just broke the surrounding trim...if i put any more force then i will end up breaking my centre console![]()
local audio ****ters want 45 quid just to remove it![]()
cool mate i did say to remove the surround. Can u not get ur hand behaind dash to push it out?
My Alpine has 2 little clips either side you need to pop out the little tags on the cage.
I'll take a picture after dinner if you want.
10 mins!
The clips are behind the surround, the wee round fellas, I'm no taking it off cause it can be a bastard to get back on lmao
AH HA...i dont think i have those lmao![]()
as mine is the screen that pops out, not a removable facia
thanks for the pictar![]()
Drill it is then![]()
****in out...got a claw hammer...need a new centre console and possibly a new dash
how many cable ties do you guys think i might need to hang my new headunit???![]()
I'd of left it in TBH, just sing.
