No radio signal or constant feed
Results 1 to 5 of 5
Thread: No radio signal or constant feed
    Nov 2007
    Southend
    Coupe turbo
    Hello guys on my mk4 astra the radio cable looks fine connected it all up and nothing dont pick anything up any ideas??
    And my cd player always forgets it self when ignition is off no constant feedi think. what can i do to check to sort this.
    Thank you
    Jun 2003
    West London
    Coupe turbo
    Re: No radio signal or constant feed
    I'm guessing you have changed the headunit? If so swap the red and yellow wires around so it keeps it's memory. If the constant feed fuse was blown the top display wouldn;t show the time/ date etc
    The aerial base's on the roof can go faulty of these cars but if it happened when you changed the headunit i'd check the aerial lead didn't get broken or possibly a faulty headunit
    Nov 2007
    Southend
    Coupe turbo
    The radio didnt work with the standard head unit either mate and cant remember if it remembered befor
    So i need to change them wires over yeh?
    Nov 2009
    Edinburgh
    IS200
    well, I know I need to change yellow and red to keep the memory (I have the same problem)
    but what about the TID Display, showing/not showing date? when HU is on, it doesn't show date, but when it's off, it shows date. I think its the usual thing for the aftermarket HU's? no?
    k3rja drivin' a l3xus :)
    Nov 2007
    Southend
    Coupe turbo
    All done thanks to the good old volt meter and your help.
    Not worried about date lol
    Radio is still ................................
