power to sub
Results 1 to 11 of 11
Thread: power to sub
    Oct 2009
    kirkliston
    power to sub
    Right have had my sub up and running now for about 4 months with no problems, until today. i jumped in the car to go to work and noticed there was no basscoming from the sub. so wen i got to work i had a look and noticed that there was no power getting to the sub. iv checked both fuses, rebolted the earth, checked the battery and the remote but still nothing
    any ideas any1
    Jay
    Jay is offline
    Oct 2008
    Fife,Scotland
    Corsa B
    Re: power to sub
    might just be the simple case that it,s funked if you reconnected everything!
    Captain we just can,t do it....just don,t have the powerrrrrr!:)
    Previously known as - Vauxhall_Redtop
    Oct 2009
    kirkliston
    Re: power to sub
    it cant be funked after only 4 mounths surley
    Moderator Nobbie's Avatar
    Hemel Hempstead
    with blue lights
    Re: power to sub
    It could be.
    Get a multi-meter to the 12v feed, see if it's got 12v at the amp end. Check for continuity to the earth, and then check for a voltage at the amp signal with the car and stereo turned on.
    If the answer is yes to all the above, check the continuity on the wire from the amp to the sub/sub box, with the car off. If it's okay to the sub box, take the sub out, and check the cable from the box to the sub. If no box, it sound like the sub needs investigation.
    Jay
    Jay is offline
    Oct 2008
    Fife,Scotland
    Corsa B
    Re: power to sub
    well you never know if its gone!how much was it?
    Gagged
    Mar 2009
    wrexham north wales
    corsa sport 1.6
    Re: power to sub
    could be the amp fried my mates works then it dont and its summit blown in the amp
    IT SOUNDS BETTER ON THE LIMITER (C20XE)
    Oct 2009
    kirkliston
    Re: power to sub
    was about £100 . ave checked the power with a test light and thats working fine and so is the earth is seems to be a problem with the remote but havent fiquered out if its at the stereo or smewhere in the cable yet will require further investigation
    Jay
    Jay is offline
    Oct 2008
    Fife,Scotland
    Corsa B
    Re: power to sub
    well usaully you find that the cheaper ones dont last long atol! But then again jst give everything a once over
    Jan 2010
    sheffield, yorkshire
    MK 2 ASTRA C20XE
    Re: power to sub
    put the remote on an ignition live this will determine if its a fault with the remote out of stereo.
    ian
    Oct 2005
    Benn's garage
    hitler's taxi
    Re: power to sub
    remote wire might have poped off...check if the amp is getting power first, if not, remove headunit and pull out the large plug then refit and it "should" start working again
    Oct 2009
    kirkliston
    Re: power to sub
    problem solved. checkee the remoe wire both at the sub and from the stero was gettin it at stereo but not at sub so was a wire fault. begin removing the wire to find it had been crused under a bolt. i just removed the cut section and were happy beating againg. thanks every1 for your help.
