Kenwood KDC 6024
On this unit there are 2 wires coloured blue/white.........according to the manual this is for antenna/power control...............does this mean one is for each? The manual doesn't mention 2. Also to connect this to an amp do i use the front pre outs or the rears?
Re: Kenwood KDC 6024
if the speakers you are amping up are in the rear then use the rear outputs then you can ajust the fader to suit, and both blue wires will or should be ok as the remote wire for the amp,
