Toad AI606 Immobiliser Problem
Results 1 to 4 of 4
Thread: Toad AI606 Immobiliser Problem
    Jul 2007
    Isle of Man
    Astra GTE 16v
    Hi People
    Got a small problem. I have wired in the toad alarm and I thought everything was fine. Car locks/unlocks as it should. Alarm sounds if I open the door with the key when alarm is armed and also goes off if I am sat in the car. So far so good.
    Now on to the problems!!
    After disarming the alarm for the first time I attempted to start the car and all electrics in the car went dead. Turning the ignition off and on did not rectify this so I disconnected the battery and reconnected it and everything worked again?? I input the pin code as suggested in the toad manual and now the alarm no longer "trips" all the car's electrics when attempting to start the car, however both immobiliser circuits do not appear to be working as I am able to start the car whilst the alarm is armed (alarm goes off but car can be driven away).
    I have wired the 4 immobiliser wires as follows: two into the fuel pump cable and 2 into what I have deduced from the car's wiring diagram to be the ignition live cable to the starter motor. In both circuits I have cut out a length of wire and soldered each of the immobiliser wires to each of the cut wires. Is this correct? Or are you supposed to just solder the immobilisation wires onto the wire/circuit at different points so that you are left with a loop?
    Any help appreciated!
    Jun 2003
    West London
    Coupe turbo
    Re: Toad AI606 Immobiliser Problem
    Everything sounds likes it's wired in correctly.
    I'm not up to speed with toad alarms but i wonder if you have put it in some sort of valet mode?
    Sep 2004
    Leeds
    Passat 130SE
    Alarm will exit Valet mode with ignition cycle
    overide immobilisors for time being may be a fault not related but happened by chance
    but what u have done sounds ok
    Ian
    Jul 2007
    Isle of Man
    Astra GTE 16v
    Thanks for the response guys, very much appreciated!
