handsfree phone kit
Results 1 to 7 of 7
Thread: handsfree phone kit
    Sep 2008
    next to edinburgh
    corsa D 1.6 turbo
    Rolleyes handsfree phone kit
    is there any good kits out there for connecting a phone (looking stock) to a cd player found in the new shape corsas? a pointer in the right direction would be appreciated.
    Jun 2005
    The Isle of Man
    1.3 Chevette L
    Re: handsfree phone kit
    I fitted a Nokia CK-7W kit in my mum's new shape corsa using an autoleads loom. The only things visible are a control button and mic. Audio is fed through the stereo. I had the same in my old Astra and similar in my wife's old Meriva. The Meriva had part of the factory prewiring installed (VDA loom) which made it even simpler.
    I believe there are also CAN interfaces available for nokia and parrot kits to use the steering wheel controls.
    Sep 2008
    next to edinburgh
    corsa D 1.6 turbo
    il look into that was just looking for pointers, i thought vauxhall might have had a standard handsfree as an option in some of the high end models?
    Jun 2005
    The Isle of Man
    1.3 Chevette L
    I looked into the Vauxhall bluetooth as a retrofit, but when I asked was told of the rediculous amount of parts required, plus dealer programming so gave it up as a bad idea. That's not to say it's not worth looing into again. From what I could tell it needed the blutooth module itself, the loom, microphone and the mono graphic display.
    Jun 2000
    Hampshire, UK
    Vectra SRi
    The vauxhall kit will be a lot of work to retro fit.
    I would suggest the nokia ck100 which just has a button and a microphone with the right autoleads or a parrot 3000 evo kit which again has just a button and a mic.
    Tom
    Sep 2008
    next to edinburgh
    corsa D 1.6 turbo
    thanks for that will probz end up with the most simple/ cheapest one!
    Feb 2003
    liverpool
    vec c slammed on 20's
    ive got a nokia one its awesome
    White euro vectra on ronals :D
