First of all Sorry its a long post, but if I don't tell you everything how could you help me otherwise! please accept my apologies for the lengthy exaplaination/
Any way guys this post is no longer relavent as I have now figured out the problem, so you can skip it but i decided to leave it on here in case anyone else may benefit from it.
thanks
recently my cally almost got stolen, the culprits broke both door locks and got in the car, badly damaged the steering lock trying to overcome the lock, which they failed sadly but left a lot of damage obviously. The car is back now with new set of door and boot locks and a matching steering lock with two keys. I transfrred the transponders into the new keys and all is fine.
so now the question is why did my factory fitted alarm not work?
I have never seen the red LED blink which is mounted on the passenger side under the roof lining in the ultra sonic sensors, this LED is suppose to come on when I TURN MY Driver's DOOR lock key to the left, and I have never seen it come on before, only by chance I noticed today there is a small button on the driver's side sensor housing which when i pressed caused the LED on the passenger side to blink for 10 seconds but nothing else happened, and then I tried to set the alarm ON using the driver's door and keys, leaving someone in the car, and when I told this guy to start moving so that if the alarm is activated it should sense the person moving inside the car and activate the alarm and sound the horn but nothing happened!
I also looked under the windscreen cowl panel, and I could see the factory fitted Alarm Sounder box there with 3 wires going into it. Could this be faulty and does it have a secondary battery inside it? as I have never seen my car sound alarm ever since I have bought this calibra, my old one did and had a black box inside the engine bay with a key switch for disabling the alarm, that was the red top but this is the eccotec,
Also when I had to disconnet the battery for carrying out some work on the car for safety you disconnect the battery, but I have never heard its alarm go off ever! my old cally used to have its alarm set off when I used to disconnect its battery unless I first disabled it first using a small alarm key, but then again it was probably an after market alarm fitted to my old cally.
Can anyone tell me if this factory fitted alarm may have been disabled by someone if so where from? or is it a question of a faulty door micro switch?
Any help will naturally be greately appriciated as always. Thanks![]()
