I've got a problem with my lock barrel, which means my radio turns off when I go over a speed bump etc. So, as you may be able to imagine this is pretty damn annoying, so I'm planning to manually wire in a switch instead of the ignition 12v.
So on my ISO connector, could I take the constand 12V, split it, and attatch it to the ignition 12V connector? (adding a switch between to control it)
Thanks in advance
