how do i install the remote cable for my sub
Results 1 to 11 of 11
Thread: how do i install the remote cable for my sub
    Oct 2009
    kirkliston
    i need to get the remote cable from the stereo to my sub but it has not attachments on it and was just wondering how i would do it
    Oct 2006
    Newcastle
    Corsa C
    Re: how do i install the remote cable for my sub
    just use single strand speaker wire mate. its just copper conductor. obviously crimped/soldered to avoid fires!!
    Dec 2002
    Essex
    Lada Riva
    You don't have a remote wire on the head unit ?
    Run a wire from somewhere that only operates when the ignition is switched on .
    This is just an example , obviuosly your amp wont work unless ignition is on .
    Oct 2006
    Newcastle
    Corsa C
    Quote Originally Posted by daddy cav View Post
    oh, i thought he meant there was no remote wire in the amp wiring kit. ie. there is a remote wire coming off the wiring loom for the head unit, but no way of connecting it to the amp in the boot?!
    Jun 2005
    Boston ,Lincolnshire
    LETAstra,V6Cav,nova
    check the loom to your radio and look for a blue wire that is normally remote wire , check with volt meter when you turn the radio on whether the blue gives a 12v, Paul
    Oct 2009
    kirkliston
    i found the blue wire but how to attach my wire to that one?
    Jun 2009
    Quote Originally Posted by DALEB View Post
    Solder?
    Crimp terminals?
    Scotch block?
    Cut the shielding off, twist the copper together and wrap in selotape?
    Oct 2009
    south africa
    corsa B 2001 1.4
    Quote Originally Posted by InternetzSrsBiz View Post
    Solder?
    Crimp terminals?
    Scotch block?
    insulation tape...
    Apr 2009
    Boston, Lincolnshire
    astra turbo convert
    easiest way, cut the blue wire, crimp a terminal to it the crimp your remote wire to that then put insulation tape round or one of them heat shrink wraps.
    May 2010
    what i do to test if the sub works is have everything linked up but the remote wire then push the remote wire by the side of the blue wire at the back of the head unit so it is touchin the metal bit inside and if it works pull the iso out of the block and use pliers to push the metal bit out and get it onto that and put it back in .. good luck tho buddy hope to hear what goes on soon
    Dec 2008
    Lincoln
    Disco 200TDI, CBR400RR
    this threads over 6 months old
    [SIGNATURE] [/SIGNATURE]
