Old 22-09-2008, 20:09   #1
Drives: Nothing until 08/09
Cav GSi 20xe starts only when jumped
hi,
after my gsi wasn't driven for a week it failed to start, flat battery i pressumed. After jumping it everything went wrong, the central locking doesnt work and the alarm goes off when i shut doors more often then when anything is opened, it seams random.
i rang the alarm company (sempal) they say to get an autolec out, this sounds expencive.
im at a bit of a loss, has anyone any ideas
the engine is fine just a bit tappety from cold its at 115k
i dont have any history or anything for the alarm but it has plenty of mot and pulls very well when it does go
thanks in advance, ryan
MK2 cavalier yo
Rysee_sri_130 is offline   Reply With Quote
Old 22-09-2008, 20:46   #2
Drives: cavalier GSI TURBO
Re: Cav GSi 20xe starts only when jumped
do the instrument panel light up with the key?
show n shine is offline   Reply With Quote
Old 22-09-2008, 20:47   #3
yes it does, all the lights seams normal, the battery light stays on
Old 22-09-2008, 20:51   #4
i dout its the immobiliser as the car starts when jumped.
can you hear the clicking noise when the key is fully turned ?
Old 22-09-2008, 20:53   #5
yeah, that normally happens when a battery is flat doesnt it?
Old 22-09-2008, 20:59   #6
new battery or fully charge the 1 you have.
Old 22-09-2008, 21:01   #7
ive tried both
Old 22-09-2008, 21:08   #8
starter has given up the ghost
Old 22-09-2008, 21:13   #9
i did whack it but ill sort out a new 1 thanks mate
Old 22-09-2008, 21:21   #10
will the starter motor see the electics right? or do i still have to get in through the boot? hahaa
Old 22-09-2008, 21:24   #11
i had a fiesta that only worked by that method.
it was funny every-time i had to start it was with a hammer.
should of seen the look on peoples faces at petrol stations car parks and the like. the only thing i was missing was a hoody.
Old 22-09-2008, 21:26   #12
hahah yeah people look at you funny for getting into a boot too hahah
Old 22-09-2008, 21:27   #13
check all your earths.
get a multi meter and check what the out put of the alternator is
Old 22-09-2008, 21:28   #14
ive got to get one for work so thats on my payday shopping list
Old 22-09-2008, 21:29   #15
what plate is it on and is it a 4x4 out of curiosity
Old 22-09-2008, 21:32   #16
hi,
i remember my cav doing the same and it turned out that the battery was fcuked and a dodgy earth strap. got it sorted and never had a problem again.
I've read on a previous thread that a dud fpr could cause this as well.
do a search mate.
Old 22-09-2008, 21:35   #17
90h 2wd in star silver
Old 22-09-2008, 21:38   #18
a trip to the scrappy is in order if it isnt that earth
Old 22-09-2008, 21:38   #19
nice car
i like the plate HERO. HAHAHAHAHA
do all your electric windows work ?
Old 22-09-2008, 21:39   #20
yeah they do
Old 22-09-2008, 21:40   #21
yeah they do
Old 22-09-2008, 21:42   #22
im pretty sure they do, i remember the fronts working because i closed the drivers window and shut the door with it running and the alarm went off, ill check the backs tomorow
Old 22-09-2008, 21:48   #23
Drives: cavalier turbo
did you buy it on micky before he moved to finland,the plate looks familiar.
i hate the world
specks is offline   Reply With Quote
Old 22-09-2008, 21:50   #24
no it came from anglesea as a swap for my 130
Old 22-09-2008, 22:23   #25
gra11's Avatar
Drives: Vectra / Corsa
i had that problem with my cav as well turned out to be a bared earth strap that was touching the bodywork when the car was running causing the alarm to go off. so get round them all al check none have broken or the rubber coating has disappeared if it has tape it up an all should be good.
Team Ecowrek all the way!!!
http://www.bebo.com/Profile.jsp?MemberId=7738292687
gra11 is offline   Reply With Quote
Members: 42,348
Threads: 307,100
Top Poster: LEE69 (42,841)
Welcome to our newest member, akbar
