14-09-2008, 18:01
#1 | | MIGWeb User
Join Date: Apr 2001 Location: West Yorkshire Drives: Vectra CDTi SRi 150
| Pioneer Avic X1BT Help Needed Hi, I removed the Pioneer AVIC from my Astra last year, It has been in storage in my garage, Nice and dry etc.
I fitted it into my Vectra today but it did not power up,
The Red Security Light flashed on and off when the facia was removed but the unit would not switch on,
Could there be a reset button or some strange wiring that I have forgotton about in all the time it was since I last fitted it, Or does the unit have to be fully installed in its case before it will work so as not to cause damage to the screen when it slides out, I just tried it while resting it on the drivers seat.
Many Thanks for any help or suggestions offered,
Kind Regards Bren |
15-09-2008, 14:02
#2 | | MIGWeb User
Join Date: Mar 2007 Location: hertfordshire Drives: cavalier GSI TURBO
| Re: Pioneer Avic X1BT Help Needed is it all conected up via the hide away box ? |
15-09-2008, 14:30
#3 | | MIGWeb User
Join Date: Dec 2006 Location: Bromley, Kent Drives: MK3 Astra 1.4i
| Re: Pioneer Avic X1BT Help Needed try giving it a constant live
Red --> Red
Yellow --> Red
(Yellow is ign live) |
15-09-2008, 14:56
#4 | | MIGWeb User
| Re: Pioneer Avic X1BT Help Needed hi. I have connected a permanent live.
I have not connected it to the hide away unit yet. I will try this when I get home tonight. Thanks. |
15-09-2008, 16:47
#5 | | MIGWeb User
| Re: Pioneer Avic X1BT Help Needed there is your problem then.
it need to be connected to the hide away box for it to function. |
15-09-2008, 17:44
#6 | | MIGWeb User
Join Date: Dec 2003 Location: staffordshire Drives: Calibra & Nova
| Re: Pioneer Avic X1BT Help Needed btw the security light illuminating means there is a a voltage of some sort down the permanent live wire (yellow) but not at the red; if its not switching on.. so check the red wire supply. Its the red wire that switches the units on. |
15-09-2008, 20:47
#7 | | MIGWeb User
| Re: Pioneer Avic X1BT Help Needed Hi. Thanks for the help. The u it now switches on and works after
connecting the brain module.
But I now have one
more problem. I cannot get the unit to fully power off. There is a fan inside the
unit that keeps spinning even when the car is locked and left. I used a autoleads connection lead to connect the unit to my veccy. I also got the steeri
by wheel adapter. But it seems the only way to connect the stereo is by using the yellow wire from the loom connected to both the red
and yellow from the stereo. The red wire from the loom just goes to the steering wheel adaptor.
I am not sure if the yellow is a permanent live but it looks like it is.
Yet so does the red.
How should it be connected
properly?
thanks.
Bren. |
15-09-2008, 21:12
#8 | | MIGWeb User
| Re: Pioneer Avic X1BT Help Needed you need to have a ignition live for that so it turns off automatically.
you might have a extended power supply that youve simply overlooked. |
15-09-2008, 21:44
#9 | | MIGWeb User
| Re: Pioneer Avic X1BT Help Needed Hi, Thanks for the reply, I will try and get a multi meter unit tomorrow and check around for an accessory live that I can use, |
15-09-2008, 21:52
#10 | | MIGWeb User
| Re: Pioneer Avic X1BT Help Needed excellent bit of kit.
do you have the reverse camera kit aswel ? |
15-09-2008, 22:19
#11 | | MIGWeb User
| Re: Pioneer Avic X1BT Help Needed no mate, no camera yet, Been looking at them on ebay, approx £190 from the states,
I have not used it much, its been in the garage for around a year, I have a Bluetooth kit and 6 disc changer connected up, I would like to know if I can connect my iphone to it so I might google that later, all my favorite songs are on the phone,
Cheers, Bren |
15-09-2008, 22:31
#12 | | MIGWeb User
| Re: Pioneer Avic X1BT Help Needed i have my ps3, xbox 360, tv dvb with a 500gb external hard drive wired up to the same unit. + a 12 disk changer.
thats in my bmw. |
16-09-2008, 20:29
#13 | | MIGWeb User
| Re: Pioneer Avic X1BT Help Needed Wow, thats a nice install, the kids would love that in our car
I still need to finish fitting mine, the weather stopped play today, Still trying to find a switched live,
I also lost my UK sat nav Disc, but Found my italian one, some good that is, lol,.
I notice an ipod option in the connections screen, Do you know if the iphone will work on the same connection?. |
17-09-2008, 13:48
#14 | | MIGWeb User
| Re: Pioneer Avic X1BT Help Needed ?? |
17-09-2008, 14:03
#15 | | MIGWeb User
Join Date: Jul 2008 Location: nr Derby Drives: V8 Senator
| Re: Pioneer Avic X1BT Help Needed Get an FM transmitter for your i-phone. They are about 25 quid from Carphone warehouse. You just tune your radio in to the frequency of the transmitter and you can listen to everything on your i-phone. Quality is fine too  |
17-09-2008, 20:46
#16 | | MIGWeb User
| Re: Pioneer Avic X1BT Help Needed Quote:
Originally Posted by Agent Kellerman Get an FM transmitter for your i-phone. They are about 25 quid from Carphone warehouse. You just tune your radio in to the frequency of the transmitter and you can listen to everything on your i-phone. Quality is fine too  | Hi Mate, I already have one of these, But I was hoping the actual ipod connection would sync with my ipod and create all the music menus on the large screen rather than me fiddle with the small p hone,
regards Brendan |
22-09-2008, 18:27
#17 | | MIGWeb User
| Re: Pioneer Avic X1BT Help Needed I got the unit fully working, Autoleads sent me a revised loom that works perfect.
I also heard reports of slow movements on the ipod connection unit so I decided not to buy it and used an RCA to jack into the AUX Input and just select songs from my iphone rather than the tough screen pioneer.
Thanks for the help and ideas.
Bren |
Members: 42,340
Threads: 307,076
Top Poster: LEE69 (42,838) | | Welcome to our newest member, Baidar | | » Join MIGClub Today | Join online
now!
of being a MIGClub Member.
