Old 30-08-2008, 15:13   #1
Drives: Corsa B 1.0 2000
Corsa b - Tweeters on handles
As i thought there are tweeters in the handles of the inside (obviously) and was planning on getting some new ones.
Should i try replacing them ones or try to fit them in a new position, i can run them to my amp in the boot but would like them in the front end of the car because the speakers and sub in the back over power it.
Also any recommendations for tweeters?
Dont post component sets because ive got new door speakers and no room for any more anywhere else in the car.
cheers
walescorsa1.0 is offline   Reply With Quote
Old 31-08-2008, 18:37   #2
Drives: Corsa C Sxi
Re: Corsa b - Tweeters on handles
when i installed components in the doors of my old corsa B, i put the tweeter in the recess where the mirror adjuster is, or was, as I had fitted M3's which were adjusted by actually pushing the mirror around with your finger!! its where vauxhall decided to put the tweeters in the newer Corsa C and D's anyway so it should sound better as the tweeter will be physically nearer your ears
hope this helps mate!
Statto is offline   Reply With Quote
Old 31-08-2008, 20:34   #3
cheers
where would i feed the wires through with that position then?
Old 02-09-2008, 14:36   #4
JoeyB's Avatar
Drives: Corsa XE & ACT.
I used the same position as factory but obviously cut out the grilles and used the tweeter cups.
///SOUTH CENTRAL MINCERS
Peter: Oh my god, Brian, there's a message in my Alphabits. It says, 'Oooooo.'
Brian: Peter, those are Cheerios.
JoeyB is offline   Reply With Quote
Old 05-09-2008, 18:17   #5
Drives: Corsa C Sxi
when you take off the mirror cover (it just pulls off), then if you havent removed the door panel you can just feed the wires up from the speaker as there is a gap about a finger wide in between the door panel at the top and the metal of the door....theres a screw there holding the door panel on which you cant see until the mirror cover is off, just so u know where the gap is that im talking about
Stevie
Old 05-09-2008, 18:55   #6
Drives: Tigra 1.8 turbo hp?
I find some nice infinitys that fit nicely in there...
Any one else has a strocked x16xe pm me.
MIG.....Made In Greece LOL
TigraTurbo is offline   Reply With Quote
Old 06-09-2008, 08:32   #7
ok i'll take a look
Old 06-09-2008, 11:15   #8
sorry wrong wright,I DO HAVE A PAIR OF INFINITYS IN THERE
Members: 42,339
Threads: 307,073
Top Poster: LEE69 (42,837)
Welcome to our newest member, David Absalom
