Old 29-08-2008, 15:07   #1
Unhappy CDR 500 muted - how can i unmute ?
Hi, I have a 2000 Zafira with a fitted Nokia car kit. Stereo has been working fine but lately it displays MESSAGE on the display and there is no sound.
I dont use the phone kit at all, its surplus to requirements. Ive eneve tried fitting an after market stereo into ( only using the speaker connector and the block with the +,-, ground, etc eliminating the top block connector). This still presents a muted stereo.
What can I do to unmute the stereo ? can i disconnect certain pins in the block or would i need to remove any added 'wiring connectors/looms' ...
Should the current stereo loom ( which I assume was addedd due to the phone kit) be detached to show the original ISO connectors ( I.e is it an add-on which if i follow back will show a connector which i can disconnect ? and then plug the original block back into the stereo ???? )
ANY ADVICE would be appreciated ...
THANKS IN ADVANCE
Curly_Wurly_6p is offline   Reply With Quote
Old 29-08-2008, 20:44   #2
Admin
Tom Williams's Avatar
Drives: Vectra Derv Wagon
Re: CDR 500 muted - how can i unmute ?
Sounds like a fuse has blown and the car kit is muting the radio.
Remove the glovebox, find car kit wiring and trace to a fuse.
If this fuse is blown, replacing it should sort the problem, or just disconnect it all
I now do not run Private Messaging on MIG.
Please email me at - tom@migweb.co.uk.
If you're query is regarding part of the website please use the helpdesk
Tom Williams is offline   Reply With Quote
Members: 42,342
Threads: 307,077
Top Poster: LEE69 (42,838)
Welcome to our newest member, dafyddgwyn
