28-08-2008, 15:58
#1 | | MIGWeb User
Join Date: Jul 2008 Location: Rhondda, South Wales Drives: Corsa B 1.0 2000
| What Sub is this?
Bought this off a friend and im not sure what sub it is, power etc
If anyone knows or has found a site with the spec on please post because i can't find anything
cheers |
28-08-2008, 16:03
#2 | | MIGWeb User
Join Date: Oct 2005 Location: london Drives: steve!'s bwm :D
| Re: What Sub is this? if you remove the sub from the box, it should be printed on the basket that holds the magnet
__________________ i sendz warningz...i haz uber phailz
volvo - the ultimate battle between rev counter and fuel gauge |
28-08-2008, 16:11
#3 | | MIGWeb User
| Re: What Sub is this? ok ill give it a go later
is it just take out the screws of the outer ring of the sub and pull it out? |
28-08-2008, 16:15
#4 | | MIGWeb User
| Re: What Sub is this? when you undo the 6 screws, the sub should come loose, will be abit tight to pull out but not tight enough to require force  but be carefull when you are pulling the sub out because there will be 2 wires going to the back of it, but they should be able to come out |
28-08-2008, 16:25
#5 | | MIGWeb User
| Re: What Sub is this? Ok thanks
Reason: .
28-08-2008, 16:53
#6 | | MIGWeb User
| Re: What Sub is this? just be carefull when removing the sub, the rest is easy...if the wires are short then you might do some damage  thats the only tricky part  |
28-08-2008, 17:14
#7 | | MIGWeb User
| Re: What Sub is this? i may just leave it im not too bothered about it, it sounds good and i dont need to know the spec
only need to know about it when i put a tidy install in but that wont be for quite a while |
28-08-2008, 17:23
#8 | | MIGWeb User
| Re: What Sub is this? its a 10 minute job  i think i just over exajurated the process  i do that sometimes and put someone off buying new alloy wheels because of insurance  |
28-08-2008, 17:29
#9 | | MIGWeb User
| Re: What Sub is this? i may do it when i have time but still im not too bothered thanks though  |
28-08-2008, 17:42
#10 | | MIGWeb User
| Re: What Sub is this? cool  |
28-08-2008, 18:19
#11 | | MIGClub Member
| Re: What Sub is this? I had a pioneer sub like that a few years ago it was a 10 inch sub 400 watt |
Members: 42,340
Threads: 307,075
Top Poster: LEE69 (42,838) | | Welcome to our newest member, Baidar | | » Join MIGClub Today | Join online
now!
of being a MIGClub Member.
