Old 22-08-2008, 07:32   #1
JoeyB's Avatar
Drives: Corsa XE & ACT.
Remote Central Locking issue Corsa C
Went and had a look at a mate of mines Corsa last night.
When you unlock the car the drivers side pin lifts, then goes back down, then lifts then goes back down....all really fast. So basically it just pulses for a bit and then locks itself again.
I took off both door cards and checked the plugs that go to the motors. The drivers side one had a white residue on two pins...at one point after cleaning them up everything seemed to be working except the door pin only twitched and didnt actually go up or down. I managed to get around that but then it went back to pulsing lol.
I disconnected the passenger side motor and the issue stayed. I did the same with the boot motor and confirmed that the issue stayed with that disconnected also.
So, is it likely that the drivers side motor is knackered?
///SOUTH CENTRAL MINCERS
Peter: Oh my god, Brian, there's a message in my Alphabits. It says, 'Oooooo.'
Brian: Peter, those are Cheerios.
JoeyB is online now   Reply With Quote
Old 22-08-2008, 19:37   #2
Drives: Coupe turbo
Re: Remote Central Locking issue Corsa C
If you use the key in the drivers door rather than the remote does the problem still happen?
autosparks is offline   Reply With Quote
Old 24-08-2008, 10:06   #3
JoeyB's Avatar
No.
Just as well really, otherwise they wouldn't be able to get into the car!!
But using the key in the drivers door only opens the drivers door. Is that normal?
Its a 3dr btw
Old 24-08-2008, 11:37   #4
put the key in the ignition , turn it on so u have dash lights n hold the unlock button for 5 seconds, this worked on a car i had.
failing that its the cl switch on the door, my cavvy used to do it.
Bazza_84 is offline   Reply With Quote
Old 24-08-2008, 12:06   #5
JoeyB's Avatar
Cheers Bazza,
Thats the method for resyncing the fob to the car isn't it? I read about it the other day and will be trying it when I get a chance.
Old 24-08-2008, 18:06   #6
Drives: Corsa C Sxi
just some gen about unlocking the drivers side door mate....if you use the key in the lock and turn it once to the left (i think) it opens the drivers door. Then re-turn the key to the left and it opens all the doors, boot included. happy days
Statto is offline   Reply With Quote
Old 25-08-2008, 13:38   #7
Drives: Coupe turbo
Turning the key to unlock in the drivers door should open just then one, usually turning it to unlock again will do the rest of the doors
Old 26-08-2008, 10:05   #8
JoeyB's Avatar
So do you think its likely to be a knackered motor?
Old 26-08-2008, 20:13   #9
Drives: Coupe turbo
Yes mate
Old 26-08-2008, 20:30   #10
JoeyB's Avatar
Cheers dude. Now just gotta wait for the car to come back from its holidays lol
Members: 42,348
Threads: 307,100
Top Poster: LEE69 (42,841)
Welcome to our newest member, akbar
