Old 07-08-2008, 15:55   #1
mikegray's Avatar
Drives: Cav V6
Alarm advice. Thatchem meaning.
I am going to have an alarm fitted to my cavalier. I have just been doing some research and im not sure on which one to get. Im not fitting it for the sole purpose of getting cheaper insurance, thats more of a bonus. Im after piece of mind.
I have to looked into the Thatchem approved alarms but im not sure about the catagories. Is that just to determine the type of alarm? The alarms I have looked at so far dont have trackers, are these classed as ad-ons or am I looking in the wrong place
I google'd alarms and it seemed to be clifford alarms did the same as the others just for more money. I also done a search on hear and it looks like there are alot of Toad alarms, is this the way to go???
As for "goodies" some of them dont mean a great deal to me lol. Total closure I pressume closes windows etc. I havent got electric windows at the moment. Is it easier to get them in first? I like the idea of remote start but didnt see it on the ones I looked at.
Really i'd like an alarm/imob tracker, remote c/l poss engine start, anything else is a bonus Looking possible budget £450 can stretch... abit
Im not to clued up on this sort of stuff so any info would be great.
Many thanks
mikegray is offline   Reply With Quote
Old 07-08-2008, 16:50   #2
Re: Alarm advice. Thatchem meaning.
i have an ai606 toad with the dual zone on my bm cab n i have piece of mind leaving it in edmonton! seems to be a gd alarm does the job, failing that i would get a clifford g650 there expensive tho
Bazza_84 is offline   Reply With Quote
Old 07-08-2008, 19:06   #3
mikegray's Avatar
Drives: Cav V6
Thanks mate, will have a look at those.
Old 08-08-2008, 06:52   #4
depends what u want it to do, if u want the dual zone etc
Old 08-08-2008, 15:37   #5
mikegray's Avatar
Drives: Cav V6
Im not really sure at the moment. Just to try and prevent it being taken. I didnt know if it was a case of, the more the better.
Old 08-08-2008, 20:47   #6
if u want to stop it being taken fit a cut out switch
Old 10-08-2008, 21:36   #7
mikegray's Avatar
Drives: Cav V6
Is that separate from the immobiliser?
Old 10-08-2008, 21:41   #8
MSG
Drives: Calibra 16V 2L P Reg
Buy a flashing LED and stick it in a little black box and mount it on the dashboard, and cost 20p save the rest of £449.80
Calibra simply Calibra
I blessed Nemesis's Calibra and he got gagged, anybody else wants their Calibra blessed?
MSG is offline   Reply With Quote
Old 10-08-2008, 21:43   #9
mikegray's Avatar
Drives: Cav V6
not a bad idea
Old 10-08-2008, 22:18   #10
MSG
Seriously though I am not kidding!! I own an Opel manta gte, in 1990when it was almost brand new and I got it home , 3 days later someone broke its front passenger door glass, it cost £80.00 just to replace that, £80.00 was a lot of money then, you could buy a whole front screen for an average family car for that whereas it only bought a front passenger door window glass.
Any way, I fitted a little black ABS box and fitted a flashing red LED, wired it to the fuse box across a certain fuse such that when you switched ignotion on the flashing LED would cut off and when you stopped the car and took keys out the dummy flashing LED would come on, ever since then no one else has ever broken into that car!!!
Old 11-08-2008, 06:28   #11
Yep, hide it some where, i have a few, my favortie it a microswitch under the seat, im only 5"6 so i garantee some1 will have to move the seat, when u do the microswitch is disconnected n the car wont start
with that, on for example the cuel pump, something else on the ignition circuit (coil wire) and another on the starter, that baby isnt going anywhere!
Old 11-08-2008, 10:49   #12
mikegray's Avatar
Drives: Cav V6
I will do that I should have all the bits I need. As for the cut off, thats a good idea. I had just remembered, one of my old cavaliers had the fuel pump running a switch hidden behind the dash. I will also do something like that. With this I might just look at a cheaper alarm, as with those cut off switch's it wont go anywhere.
Its good no one has broken into it since, have you put an alarm sticker on any of the glass?
Old 17-08-2008, 15:59   #13
Drives: Passat 130SE
Thatcham Cat2 is immobilisor
Cat 1 is alarm immobilisor
Toad Gemini they are all up to it as long as its fit well
Ian
www.mobilecaralarms.com
MR_TOAD is offline   Reply With Quote
Members: 42,344
Threads: 307,080
Top Poster: LEE69 (42,838)
Welcome to our newest member, aooiuun
