Old 29-01-2008, 20:25   #1
CDR500 faceplate query.
Hi all, i have a CDR500 with the faceplate missing, will any faceplate fit? just wondering as it's the set thats coded, not the faceplate. Cheers.
tool eater 16v is offline   Reply With Quote
Old 29-01-2008, 20:33   #2
Admin
Tom Williams's Avatar
Drives: Vectra Derv Wagon
should do yes.
Tom Williams is offline   Reply With Quote
Old 06-02-2008, 19:16   #3
you can fit a new removable panel but you will have to re enter the code for the stereo (not the panel) to use it again
RoopDAscoop is offline   Reply With Quote
Old 06-02-2008, 21:17   #4
Cool, cheers all.
Old 23-09-2008, 19:28   #5
Re: CDR500 faceplate query.
hi i tryed that myself ive got the booklet it says the face off bit is coded to your stereo ive got same problem of to vauxhall i thinkmine just displays the word panel i got a new one just says the same
crofty123456 is offline   Reply With Quote
Old 24-09-2008, 13:53   #6
it says the word PANEL because you have changed the panel from the original one
this is normal
you need to enter the code you have for YOUR CD player
if you have lost the code for your stereo you will need to either get it or get it recoded
it has nothing to do with the panel
Old 24-09-2008, 14:41   #7
Drives: Astra 3 CDX 2.0 16v
Just make sure you get the correct brand remember AC Delco and Siemens VDO made them
Cesarokiddy is offline   Reply With Quote
Old 25-09-2008, 08:46   #8
i think you can use Philips panels in AC Delco radios as i have done this
but i'm sure VDO Siemens must be the same type (never tried a Delco or Philips one in them)
worth a try though...
if you need a VDO Siemens panel i have one for sale
Old 25-09-2008, 16:54   #9
hi just been vauxhalls with mine they say if you have a late model vdo stereo the same as me you panel is coded to stereo if u have a 51 plate or before just a new panel will slot straight on
Members: 42,343
Threads: 307,079
Top Poster: LEE69 (42,838)
Welcome to our newest member, Sp33dFr33k
