6x9s in Cav mk3
Results 1 to 8 of 8
Thread: 6x9s in Cav mk3
    Aug 2001
    SouthWest
    Cavalier V6 4WD
    6x9s in Cav mk3
    Hope some one on here can help me out. I've just got a pair of 6x9s(for free,won them before you ask) and I am wondering wether or not it's possible to get them in the rear shelf of my cav mk3 saloon? It looks fairly structural to the car so I don't want to go cutting metal out that should be in there. Any ideas any one?Please?
    Mar 2001
    Torquay
    LC 20VT
    im preety sure you have to cut the shelf(the metal bit)to get them in.the other way is to put a spacer between the speaker and shelf to raise it so the magnet isnt so far down?
    ps glad i got an hatchback
    Noz
    Noz is offline
    Jun 2000
    Wolverhampton
    Vectra SRi V6
    You CANNOT cut the metal shelf, its an MOT failure (of course, that's if they check!!!). However, I seem to remember there are cutouts that can house a smaller speaker magnet. You might still have to build a spacer to lift the 6x9's up out of the shelf a bit.
    They can also be installed in the doors with a suitable build, if you're feeling adventurous.
    Aug 2001
    SouthWest
    Cavalier V6 4WD
    What do you mean about the cut outs? The magnet should go thru the hole fine, it's the basket thats the prob.
    Lee69- Yeah the hatchback is better for ice, but the saloon is sooo much better looking .Basically then I've either got to cut the shelf or build in some spacers? Any one sell a rear strut brace for the cav Mk3 as well??
    Sep 2000
    West Country
    Cavlad - I have fitted many a stereo in my time.
    If you want I will have a look at building a spacer or door pod for you if you want.
    Regards
    As you get older the toys just get more expensive.
    Aug 2001
    SouthWest
    Cavalier V6 4WD
    Thank you very much Rob, I may just well take you up on that. Have a word with you at trax if I see you.Don't trust myself too much with an interior.
    p.s whats it gonna cost me?
    Apr 2001
    Surrey
    Cav SRi
    You can just bolt them up from underneath and they will fire through the standard hole. I did this in my Cav Saloon back in '97 so I can't remember tha clearly but I don't think I even needed to make a spacer and they worked fine!
    Aug 2001
    SouthWest
    Cavalier V6 4WD
    Thank you Mr.Ben. I decided to try that and it worked treat! Used the grilles as spacers and all is fine. Sounds nice to
