corsa b doorcards
what size sony speakers will fit in the doorcards and what connections wil need ?????
thanks
the front components are 6.5" (16.5cm), not sure about the size of the speakers that fit behind them depth-wise (as some will knock on the windows when they are wound down due to bigger mounting depths). Best bet is to pull the speakers out from your doorcards when looking at new ones and size the old ones up against the new ones. it's only a 5 minute job to get the old ones out
