any good?
Results 1 to 5 of 5
Thread: any good?
    Oct 2006
    oswaldtwistle
    mk3 astra california
    any good?
    i am looking through ebay for some 6x9's for my install that iam currently doing and i come across these:
    http://cgi.ebay.co.uk/Car-speakers-6...QQcmdZViewItem
    but i want it to all be jbl so what do you think of these:
    http://cgi.ebay.co.uk/JBL-6x9s-6x9-G...QQcmdZViewItem
    thanks in advance
    ps wollopsri what neons did you use in your jbl gto amplifier? thanks
    5drs are the way forward
    MK3OC.COM-migweb.co.uk-vauxonline.co.uk
    Gagged
    Jun 2005
    Manchester
    Vectra GSi
    first ones look cheap and nasty
    those jbl are i think the ones used in standard cars ie original equipment.
    you really do get wh you pay for in stereo stuff but out of the two id stick to the good named gear
    Nov 2004
    derby
    cav 93 sri red top
    i used some cheap and tacky MAX POWER led lights. wouldn't recommend them to be honest.
    i'm shortly going to be replacing them all with some cold cathode computer lights.
    an example;
    http://cgi.ebay.co.uk/New-Dual-12-Bl...QQcmdZViewItem
    search result-- http://search.ebay.co.uk/search/sear...e=cold+cathode
    the main boot lights are VARAD.
    with regards 6x9's;
    i personaly wouldn't use any of the ones you've linked to, but, out of the two, i would opt for the JBL,(assuming you will be driving them with a suitable amp, they are 2ohm speakers).
    my preference would be JBL power series 6x9's,(they come with voice matched crossovers), but at about 100 pounds a set may be above your budget.
    Oct 2006
    oswaldtwistle
    thanks mate you have helped me out alot again cheers.the cold cathode lights are very bright and you can get them cheaper than the link on ebay.i have got some to light up the boot .i will post pics when my build is done
    Oct 2006
    oswaldtwistle
    Quote Originally Posted by Lawrence* View Post
    thanks lawrence,yeh i thought that the first set looked really cheap and tacky
