loudness from speakers
Results 1 to 5 of 5
Thread: loudness from speakers
    Apr 2003
    Birmingham
    Corsa SRi
    currently in my corsa sport i have...
    pionner head unit (all speakers connected to head unit)
    standard speakers in doors
    pionner 6x9s in rear shelve
    jbl 300wrms sub in boot, run by a kenwood 4ch amp
    not much i know, but it does the job, anyway, before, it was ok, i could hear enough bass, even on low volume, and i could hear the sound from the rear speakers over the fronts
    but, a few weeks back, i needed to test the kicker kx800.2 amp, so i disconnected the kenwood amp, and wired up the kicker amp, not touching the speakers at all, tested the amp, worked fine (except for one channel broke!) enough bass from sub, etc
    so i disconnected the kicker, and reconnected the kenwood, not altered any settings on either head unit or amp
    but lately, the sound has moved, i can hear the front speakers over the 6x9s or any bass, i have to turn it up loud to hear anything, but sound is coming out, even at low volume
    so whats the problem?
    cheerz ta very mooch!
    If It Comes Off, Modify It!
    Cruise-Mids.com ~ The Cars, The People, The Scene!
    Nov 2004
    derby
    cav 93 sri red top
    sounds like a phasing issue mate.
    check headunit menu for a phasing feature,(will give two options 0 degrees or 180 degrees).
    check all speaker wiring from the amp is wired with the correct polarity,(+ve to +ve, -ve to -ve).
    Apr 2003
    Birmingham
    Corsa SRi
    checked them this morning, theres no fader (F/R) on it, only a balance (L/R) and thats fine!
    Jan 2007
    some pioneers have something called 'front image enhancement' built in (FIE in the audio menu). Basically, this controls the bass output to the front speakers, turning off the bass output for the speakers past a certain frequency. If this is wrong (could have been reset if you disconnected the battery terminal(s) at any point) then the sound may be out as you described.
    also, the equalizer may have the treble settings turned up too high, or the bass too low. try looking through the audio settings on the head unit to see if this is the case.
    Hope this helps.
    PS what head unit is it?
    Nov 2002
    London
    Vectra sri150 n
    at a guess it sounds like the 6x9 are out of phase with each other.
    Try disconnecting the sub and seeing if you can hear the 6x9s any better.
    Try swapping the speaker wires over on the sub and see what happens.
    Otherwise it will probably be a head unit or amp setting that got changed by accident.
    Is it just the sub that is running off the amp?
