Astra 2000 Wiring
Sorry ill bet this has been covered but i cant find it (probably because it helps to be able to spell when using the search).
Im gunna be wiring my mates amp up tonight and he wont have found out the best way so;
Wheres the best route for the power lead to run - battery to boot?
Headunit to amp im guessing along past the gear stick and under the back seats, anything i should be aware of?
Unless the astra has fly by wire throttle (no cable) your going to have to drill a hole in on the passenger side
lmao You should have seen it! My mate decided the best route would be down through the wing and in through the rubber door seal (bottom)! Obviously this didnt work as the door needs to close! lmao
Sometimes i wonder why i bother
