Astra G alarm & tech 2/OBD
Results 1 to 9 of 9
Thread: Astra G alarm & tech 2/OBD
    Dec 2005
    Manchester
    Mk4 Astra Cab 2.2
    Hi
    Still having problems with the astra's alarm - before going out and spending on guessed parts, is there any tool like an obd scanner or tech 2 scanner that will highlight any failings? Anyone in manchester who can do a scan?
    Thanks.
    2002 Astra mk 4 2.2 Convertible Piper Panel filter.
    1996 Saab 9000 Aero; 225bhp of boosting pleasure.
    Jan 2005
    Newport
    Focus LX
    Whats wrong with it?
    Apr 2005
    Sheffield
    Citroen C4
    Im guessing its the alarm dongle
    Jan 2005
    Newport
    Focus LX
    Quote Originally Posted by random ryan View Post
    Yes whats wrong with the alarm you tit.
    Dec 2005
    Manchester
    Mk4 Astra Cab 2.2
    From previous posts and a bit of a google, the issue seems to be a dodgy powersounder - random/intermittent alarm going off, sometimes dropping the roof, windows, open/close the bonnet/boot works, other times the car is fine for a week or 2 then, like this weekend the alarm has been a nightmare, going off anywhere from 5 seconds to 8 hours after each reset.
    Sounding like the powersounder battery thing, which I have read you can split and throw some new batteries on (ignition se to on during battery change phase to not need tech2), or obtain a new unit from Vaux (which I assume needs 'marrying'/tech2 to the car if it is a new unit)
    My area of expertise is Saab, I am getting more excuses to spend the cash on a real tech 2 (not an ebay ripoff) with 2 cards - one for the saabs, one for the astra!! Gotta love GM eh?
    Thanks for the quick responses!
    Rob
    Rob is offline
    MIGWeb User Rob's Avatar
    Tain
    Vectra CDTi
    Don't spend money on a tech2 session. It will be the power sounder.
    The unit is reasonably cheap from vaux and its a ten minute job to fit.
    Melv - "you shouldn't be allowed boobs that size as your only a wee lassie"
    Jan 2005
    Newport
    Focus LX
    Does sound like the power sounder. Unfortunately the only place that i knew that stocked the batterys don't do them any more, they might have a couple left but not many if any. Its a dead easy job, just jack the passenger side up, two torx screws to remove the wheel arch trim and you should see it. two more torx screw to remove the alarm then simply remove the plug. Once its out, if you can get hold of batterys then you need to cut along the centre line to expose the insides. I just replaced mine as a whole as mine had leaked battery fluid all over the inside. Mine cost £57 from Vaux.
    Dec 2005
    Manchester
    Mk4 Astra Cab 2.2
    Thanks guys, If I replace, do I not need to get the car to recognise? Or is it the same as the battery method, ie having the ignition switched to on and there is no need to marry?
    Thanks again (incedentally, until i get a replacement, can I just disconnect the sounder? Will this cause problems?)
    Dec 2005
    Manchester
    Mk4 Astra Cab 2.2
    Quote Originally Posted by mattcoupturbo View Post
    Do you happen to remember the company name/battery code (please pm for email address if external linking is barred etc)
    Thanks again guys.
    Luke.
